[postgis-users] Using/Compiling PostGIS on WindowsXP/Cygwin for use with PostgreSQL
Rudolf Nottrott rnott at alexandria.UCSB.edu
Fri Jun 25 16:55:13 PDT 2004
Following Tylers insights, I decided to disable proj4 and geos in the Makefile:
USE_PROJ=0    and
USE_GEOS=0
Now PostGIS at least compiles and installes ok (just a few warnings but
errors are gone).
I just want to get the basic PostGIS going first,
Thanks,
Rudolf
At 05:45 PM 6/25/2004 -0600, you wrote:
>That is correct, fortunately the builds for these projects are really
>good and work on both linux and windows.  Just download them and follow
>the build instructions.  It's easier than you might think.
>Martin
>-----Original Message-----
>From: Rudolf Nottrott [mailto:rnott at alexandria.UCSB.edu]
>Sent: Friday, June 25, 2004 5:25 PM
>To: PostGIS Users Discussion
>Subject: RE: [postgis-users] Using/Compiling PostGIS on WindowsXP/Cygwin
>Are you saying that proj4 and geos are required to run
>PostGIS with PostgreSQL on Windows/Cygwin?
>Are they also required to run PostGIS with PostgreSQL on other
>platforms,
>in particular Linux?
>If so, that adds up to quite an installation chore, mostly because of
>the
>potential errors that can occur.
>I feel a bit daunted!
>Rudolf
>At 05:01 PM 6/25/2004 -0600, you wrote:
> >You need to download and install proj4.  It's the projection library
> >used by postgis to handle projecting lat/lons into x,y and the inverse.
> >The zip can be found at http://www.remotesensing.org:16080/proj/ .
> >Follow the build instructions for windows using the vc compiler.  Let
> >me know if you have problems.  You also need geos which can be found at
> >http://geos.refractions.net .
> >Martin Chapman
> >Sent: Friday, June 25, 2004 4:56 PM
> >To: postgis-users at postgis.refractions.net
> >Subject: [postgis-users] Using/Compiling PostGIS on Windows XP/Cygwin
> >Hello,
> >I have been using PostGIS 7.4.3.1,  running under Cygwin on Windows XP,
> >and that works fine.
> >Now I want to add  PostGIS, but during the installation I get
> >compilation errors, as outlined below.
> >Has anybody done this, I mean successfully installed and used PostGIS
> >with PostgreSQL on Windows XP?
> >Would you please give me some advice here?
> >Thanks for your help and support.
> >Rudolf
> >DESCRIPTION OF THE PROCEDURE THAT RESULTS IN ERROR "projects.h: No such
> >file or directory":
> >So to install PostGIS with PostgreSQL on Windows XP/Cygwin I followed
> >the
> >instructions at
> >http://www.gasai.com/gisapps/WindowsHowTo.html#Set%20up%20PostGIS
> >section "Set up PostGIS",  which includes
> >- getting postgis-0.8.1.tar.gz
> >- putting it into the PostgreSQL contrib directory
> >      usr/src/postgresql-7.4.3-1/contrib
> >- untaring/unzipping it there, which results in a directory
> >      usr/src/postgresql-7.4.3-1/contrib/postgis-0.8.1    and
> >- running
> >      'make' in
> >- When I run that last 'make', I get an error about missing
> >    projects.h, as follows
> >$ make
> >gcc -O2 -fno-strict-aliasing -Wall -Wmissing-prototypes
> >-Wmissing-declarations -g -fexceptions   -I. -DFRONTEND
> >-DSYSCONFDIR='"/etc/postgresql"'  -DUSE_VERSION=74
> >-I/usr/local/include/geos -DUSE_GEOS -I/usr/local/include
> >-DUSE_PROJ  -DUSE_STATS  -I../../src/include   -c -o
>postgis_transform.o
> >postgis_transform.c
> >postgis_transform.c:52:22: projects.h: No such file or directory
> >postgis_transform.c:55: error: syntax error before '*' token
> >postgis_transform.c:55: warning: type defaults to `int' in declaration
> >of `make_project'
> >postgis_transform.c:55: warning: data definition has no type or storage
> >class
> >postgis_transform.c:59: error: syntax error before '*' token
> >postgis_transform.c:64: error: syntax error before '*' token
> >postgis_transform.c:67: warning: no previous prototype for
> >`pj_transform_nodatum'
> >etc., etc.
> >In an attempt to install PostGIS into my existing PostGIS 7.4.3.1, I
> >followed the instructions at
> >which include
> >Rudolf
> >Santa Barbara
> >Rudolf Nottrott
> >University of California Santa Barbara     Phone: (805) 893-6146
> >Department of Computer Science           E-mail:
> >RNott at Alexandria.UCSB.edu
> >Alexandria Digital
> >Library                       Web:    www.alexandria.ucsb.edu
> >Santa Barbara, California  93106
> >_______________________________________________
> >postgis-users mailing list postgis-users at postgis.refractions.net
> >http://postgis.refractions.net/mailman/listinfo/postgis-users
