[postgis-users] could not find function "centroid" in file "/usr/lib/postgresql/postgis.dll"
strk
strk at keybit.net
Sun Jun 27 03:33:40 PDT 2004
What version of postgis are you trying to build ?
Check if postgis_fn.c contains a line in the form:
#if ! USE_GEOS
If it does try substituting it with:
#ifndef USE_GEOS
and recompile
--strk;
On Sat, Jun 26, 2004 at 07:57:00AM -0700, Rudolf Nottrott wrote:
> I installed PostGIS with PostgreSQL on Windows XP / Cygwin, after switching
> off proj4 and geos in the Makefile (USE_PROJ=0 and
> USE_GEOS=0). I switched off proj4 and geos because I was getting PostGIS
> compilition errors without them installed, and I felt a bit daunted
> about two more installs.
> WIth
> USE_PROJ=0 and USE_GEOS=0
> PostGIS compiles and installes ok -- I just wanted to get the basic
> PostGIS going first.
> Unfortunatley, now when loading the postgis.sql definitions file
> psql -d drg_usgs -f postgis.sql
> I get an error
> Any idea what that means, and what to do?
> Thanks,
> Rudolf
> P.S. I thought that perhaps it relates to the uninstalled geos, so I
> downloaded and unpacked geos, but then found no installation instructions
> for it (only an empty README file).
> >Subject: RE: Using/Compiling PostGIS on WindowsXP/Cygwin for use with
> >PostgreSQL
> >Date: Fri, 25 Jun 2004 17:45:25 -0600
> >From: "Chapman, Martin" <MChapman at sanz.com>
> >To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> >That is correct, fortunately the builds for these projects are really
> >good and work on both linux and windows. Just download them and follow
> >the build instructions. It's easier than you might think.
> >Martin
> >-----Original Message-----
> >From: Rudolf Nottrott [mailto:rnott at alexandria.UCSB.edu]
> >Sent: Friday, June 25, 2004 5:25 PM
> >To: PostGIS Users Discussion
> >Subject: RE: [postgis-users] Using/Compiling PostGIS on WindowsXP/Cygwin
> >for use with PostgreSQL
> >Are you saying that proj4 and geos are required to run
> >PostGIS with PostgreSQL on Windows/Cygwin?
> >Are they also required to run PostGIS with PostgreSQL on other
> >platforms, in particular Linux?
> >If so, that adds up to quite an installation chore, mostly because of
> >the potential errors that can occur.
> >I feel a bit daunted!
> >Rudolf
> >At 05:01 PM 6/25/2004 -0600, you wrote:
> >>You need to download and install proj4. It's the projection library
> >>used by postgis to handle projecting lat/lons into x,y and the inverse.
> >>The zip can be found at http://www.remotesensing.org:16080/proj/ .
> >>Follow the build instructions for windows using the vc compiler. Let
> >>me know if you have problems. You also need geos which can be found at
> >>http://geos.refractions.net .
> >>Martin Chapman
> postgis-users mailing list
