[postgis-users] How retrieve number of points based on scale value?
strk
strk at keybit.net
Tue Mar 16 00:41:32 PST 2004
On Fri, Mar 12, 2004 at 12:57:07PM +0100, Maurizio Napolitano wrote:
> > I couldn't seen the java map,
> The effect is very impressive
> > but I suspect this is something
> > I've already handled to do.
> Good!
> > I made a stored procedure which
> > transformed a postgis geometry making each of its points fall
> > on a grid defined by its origin and cell size. Adiacent points
> > falling an the same cell are merged togheter thus making the
> > geometry smaller (in points and size) as you enlarge the 'grid'.
> > It's like mapsever's raster-based reduction.
> > Is this what you're looking for ?
> mmm ... probaly ...
> Do you can send me your procedure?
You can get a packaged version at:
http://foo.keybit.net/~strk/postgis/apply_grid-0.3.tgz
> Do you know OpenENV?
> If you load a geotiff, with OpenENV, the software manage the image
> by reduce the number of pixel for each scale.
Take a look at this:
http://foo.keybit.net/~strk/mapview/
> Thanks!
You're welcome.
--strk;
