[postgis-users] DropGeometryColumn
Benjamin Wragg
bwragg at tpg.com.au
Thu Mar 18 11:55:04 PST 2004
When I get this I just do the following:
Delete from geometry_columns where f_table_name like
'Name_Of_Spatial_Table_Deleted';
Cheers,
Benjamin Wragg
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Jan
Hartmann
Sent: Friday, 19 March 2004 4:12 AM
To: PostGIS Users Discussion
Subject: [postgis-users] DropGeometryColumn
I don't know if I diagnosed this problem correctly, but I regularly
stumble over the following situation:
I create a spatial table, and delete it after some time. When I create a
new spatial table under the same name, I get an error message about
"duplicate geometry column names". It seems that before deleting a
spatial table, you *have* to drop manually the geometry column of that
table with DropGeometryColumn(). I don't know how to remove this column
after deleting the table, so this leaves me with a database where I
cannot create tables that have been deleted the wrong way.
Am I right that this is how it works? If so, could it be remedied, e.g.
by some sort of trigger on dropping a spatial table?
Jan
postgis-users mailing list postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
