[postgis-users] Schema support in loader/dumper]
strk
strk at keybit.net
Thu Mar 18 19:43:31 PST 2004
On Fri, Mar 19, 2004 at 10:06:56AM +0100, Jan Hartmann wrote:
> Hi strk,
> Perhaps I'm doing something very dumb. However,
> bin_0.8.0/shp2pgsql -s 28992 -d test.shp test zl > test.sql
> psql -d zl -f test.sql
> works, while
> bin_0.8.1/shp2pgsql -s 28992 -d test.shp test zl > test.sql
> gives the following errors
Can you send a diff of the two outputs (or send them all) ?
> psql:test.sql:1: ERROR: column not found in geometry_columns table
This seems to come out from DropGeometryColumn
> DROP TABLE
> psql:test.sql:3: NOTICE: CREATE TABLE will create implicit sequence
> "test_gid_seq" for "serial" column "test.gid"
> CREATE TABLE
> psql:test.sql:4: ERROR: Invalid database name.
This is probably coming from AddGeometryColumn
But it's a long time it doesn't issue that message anymore.
What version of postgis is installed ?
--strk;
> BEGIN
> psql:test.sql:6: ERROR: column "the_geom" of relation "test" does not exist
> psql:test.sql:7: ERROR: current transaction is aborted, commands
> ignored until end of transaction block
> psql:test.sql:8: ERROR: current transaction is aborted, commands
> psql:test.sql:9: ERROR: current transaction is aborted, commands
> psql:test.sql:10: ERROR: current transaction is aborted, commands
> psql:test.sql:11: ERROR: current transaction is aborted, commands
> COMMIT
> psql:test.sql:12: NOTICE: ALTER TABLE / ADD PRIMARY KEY will create
> implicit index "test_pkey" for table "test"
> ALTER TABLE
> setval
> postgis-users mailing list
