[postgis-users] WKB to native geometry using BULK COPY
strk
strk at keybit.net
Wed Mar 24 09:37:19 PST 2004
Check for PQexecParams in libpq dox.
See GeomFromWkb in postgis.
--strk;
On Wed, Mar 24, 2004 at 09:16:15AM -0800, Ryan Proulx wrote:
> Any thoughts on this yet? Or is this just a really stupid question? I am open to suggestions on how to make transfering data in and out of PostGIS easier.
> Regards,
> ryan
> -----Original Message-----
> From: Ryan Proulx
> Sent: March 4, 2004 16:02
> To: PostGISUserGroup (E-mail)
> Subject: [postgis-users] WKB to native geometry using BULK COPY
> Greetings,
> I am curious how I can use the COPY commands to insert literal geometry data. Currently this works with WKT by specifying the geometry as:
> 'srid=<srid>;<the_geometry_as_wkt>'.
> However, I would like to do the same thing using WKB. Any ideas on how that might successfully be done?
> It seems I will have to get an SRID and a WKB geometry, in hex preferably, and combine the two to form a single hex literal to be inserted directly into a column of type GEOMETRY.
> When I am using single INSERT statements instead of the COPY commands I use the 'geomfromwkb' function to combine the SRID and WKB hex string, so I guess what I really need to know is how this is accomplished and likely what the native underlying geometry looks like.
> Regards,
> ryan
> postgis-users mailing list
