[postgis-users] Bounding Box Query
Tyler Mitchell
TMitchell at lignum.com
Mon Mar 29 09:15:53 PST 2004
Do you have the x,y coordinate pair in a table in the database?
Do you have the road data in a table too?
postgis-users-bounces at postgis.refractions.net wrote on 03/29/2004 08:40:07
AM:
> Hi Tyler,
> This is the first time I am getting a response from member listers.
> Thanks for inquiring.,
> Can you repost your response, please?
> >From: Tyler Mitchell <TMitchell at lignum.com>
> >Reply-To: PostGIS Users Discussion
<postgis-users at postgis.refractions.net>
> >To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
> >CC:
> >postgis-users at postgis.refractions.net,postgis-users-
> >Subject: Re: [postgis-users] Bounding Box Query
> >Date: Mon, 29 Mar 2004 08:36:30 -0800
> >Are you getting email from the list okay? A couple of us had responded
a
> >week or so ago...
05:51:08
> >AM:
> > > I had posted this question here before but didn't get any response.
> > > I was encouraged to try it again.
> > > I have a query that retrieves an address closest to a point given an
x/y
> > > coordinate pair.
> > > This is that query:
> > > SELECT str_num || ' ' || name as full_address,
> > > distance(the_geom,'POINT(2227284.1963667543
> > > 1435389.6730164126)'::geometry) as dist
> > > FROM address
> > > ORDER BY dist limit 1
> > > The above query works as far as returning the closest address to a
point
> > > based on x/y coordinate pair.
> > > Hower, performance is really bad as it takes quite sometime for this
> >query
> > > to retrieve a record.
> > > I have a about bounding boxes or overlap operator (&&) as a means of
> > > improving performance.
> > > I don't quite understand it how works.
> > > For instance, given the below query (which doesn't work by the way),
> > > FROM address
> > > WHERE the_geom && 'BOX3D(90900 190900, 100100 200100)'::box3d
> > > AND distance( the_geom( 'POINT(2227284.1963667543
> >1435389.6730164126)',
> > > -1 ) ) < 100
> > > My questions are:
> > > 1, how are the arguments in bo3d shown below generated? I just
filled in
> > > those numbers without knowing where they come from or how they are
> > > generated.
> > > -1 ) ) < 100
> > > 2, how can I apply the information on question 1 to with the query
above
> > > (the one indicated as a working code)?
> > > All research I have done so far have not helped me.
> > > Your assistance is greatly appreciated.
> > > _________________________________________________________________
> > > All the action. All the drama. Get NCAA hoops coverage at MSN Sports
by
> > > ESPN. http://msn.espn.go.com/index.html?partnersite=espn
> > > postgis-users mailing list
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Get rid of annoying pop-up ads with the new MSN Toolbar – FREE!
> http://toolbar.msn.com/go/onm00200414ave/direct/01/
