[postgis-users] gps points to postgis
Mike Jackson mj at sci.fi
Tue Nov 2 13:04:35 PST 2004
Markus Schaber (schabios at logi-track.com) wrote:
> I think, in your case, it absolutely makes sense to store 8500 points in
> a single Linestring, as it is a single trip.
> As soon as your objects are large enough, you need this much points to
> describe them with the needed accuracy.
Hi Markus,
 Thanks for the response. You have some records which contain quite a lot of points,
and I assume that it works for you or you wouldn't be showing it here. I don't feel
so uncertain about storing all of those points into one record now. Perl time :-)
Thanks,
Mike
