[postgis-users] Re: molodensky
Frank Warmerdam
warmerdam at pobox.com
Wed Nov 3 06:34:40 PST 2004
pinktomate wrote:
> hi all
> postgis is able to work with datum transformations for instance the
> molodensky badekas model for transformatiosn of datum??
Dear Pinktomate,
PostGIS uses PROJ.4 for coordinate transformation, so the question is what
does PROJ.4 support. It support 3 and 7 parameter data transforms as well
as the use of grid shift files in a few formats.
I am a little fuzzy on proper mathematical names for the different transforms.
I believe the 3/7 parameter transforms are molodensky transforms (or perhaps
Bursa-Wolf transforms) but they are the normal methods used by other packages.
I just utilized the code from Geotrans from NIMA for PROJ.4.
In particular the 3 parameter transform is a 3D offset in geocentric space.
The 7 parameter includes rotation and scaling factors as well as the offset
in geocentric spaces.
This is discussed at:
http://proj.maptools.org/gen_parms.html#towgs84
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
