[postgis-users] Error running "psql -f lwpostgis.sql -d mydat abase" during installation
RIBOT, Nicolas nicolas.ribot at astrium.eads.net
Thu Nov 4 01:37:13 PST 2004
Hello Antonio,
you should look at the firt error line in the message: It will give you the
source error. All other errors are due to the first one: after the first
error, the DB transaction is canceled.
In my case, error messages with the postgis.sql file are often due to a bad
path to the postgis library.
Anyway, have a look at the firt error.
Nicolas
> Hello:
> I have a problem during the last step of the installation of
> PostGIS v.
> 0.9.0 (Ihave downloaded the last version from CVS yesterday) with
> PostgreSQL 8 beta 3. When I run the "psql -f lwpostgis.sql -d
> mydatabase",
> I obtain the next error message. This is only the bottom part of the
> message, because the top part is a lot of transactions
> aborted similar than
> this:
> psql:/usr/local/pgsql/share/lwpostgis.sql:2692: ERROR:
> current transaction
> is aborted, commands ignored until end of transaction block
> ROLLBACK
> Could anybody help me?
> Thank you very much in advance,
> Antonio
> postgis-users mailing list
CE COURRIER ELECTRONIQUE EST A USAGE STRICTEMENT INFORMATIF ET NE SAURAIT ENGAGER DE QUELQUE MANIERE QUE CE SOIT EADS ASTRIUM SAS, NI SES FILIALES.
SI UNE ERREUR DE TRANSMISSION OU UNE ADRESSE ERRONEE A MAL DIRIGE CE COURRIER, MERCI D'EN INFORMER L'EXPEDITEUR EN LUI FAISANT UNE REPONSE PAR COURRIER ELECTRONIQUE DES RECEPTION. SI VOUS N'ETES PAS LE DESTINATAIRE DE CE COURRIER, VOUS NE DEVEZ PAS L'UTILISER, LE CONSERVER, EN FAIRE ETAT, LE DISTRIBUER, LE COPIER, L'IMPRIMER OU EN REVELER LE CONTENU A UNE TIERCE PARTIE.
This email is for information only and will not bind EADS Astrium SAS in any contract or obligation, nor its subsidiaries.
If you have received it in error, please notify the sender by return email. If you are not the addressee of this email, you must not use, keep, disseminate, copy, print or otherwise deal with it.
