RES: [postgis-users] Double Precision Geometry
Gustavo Oliveira gustavo.oliveira at 3WT.com.br
Thu Nov 4 03:57:38 PST 2004
When I tried to store something like this:
INSERT INTO map_cdc (column, column1, column2, column3, column4, column5)
VALUES (1, 1466, 264, NULL, GeometryFromText('POINT(201610.02590000001
7562744.5816000002)', -1), 2122);
the stored data appears truncated...
select * from map_cdc order by id;
column |column|column2| column3     |                  column4
|column5
     1 | 1466 |   264 |             | SRID=-1;POINT(201610.0259
7562744.5816) |   2122
Is there any way to do this select get exactly what I store?
[]s
Gustavo
-----Mensagem original-----
De: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]Em nome de
strk at refractions.net
Enviada em: quinta-feira, 4 de novembro de 2004 09:34
Para: PostGIS Users Discussion
Assunto: Re: [postgis-users] Double Precision Geometry
On Thu, Nov 04, 2004 at 09:30:08AM -0200, Gustavo Oliveira wrote:
> Hi!
> Is there any way to store double precision points using geometry type?
> []s
> Gustavo
All postgis geometries are Double Precision.
--strk;
> postgis-users mailing list
