[postgis-users] error in isvalid function
ksa
ksa-nil5 at yandex.ru
Fri Nov 5 00:42:46 PST 2004
okay, hole is really invalid. But how I can handle of this situation? If I
*already* have polygones with similar holes. Which function I can use to
determinate this without getting an exception?
> I've verified your query.
> The Polygon is actually invalid due to degenerate hole (as the
> exception states).
> When extracting the rings, these are handled as LINESTRINGS, for which
> the degenerate case is not checked.
> Which do you think would be a better handling of this situation ?
> --strk;
> On Fri, Nov 05, 2004 at 09:17:01AM +0300, ksa-nil5 wrote:
> > >> Hi, all!
> > >> I'm working with follow data (POLYGON):
> > >> POLYGON((37.654639 55.726496,37.654056 55.726947,37.653801
55.727333,37.653801 55.727435,37.654468 55.727483,37.656654
55.727466,37.656572 55.727063,37.656654 55.726713,37.657052
55.726531,37.657571 55.726365,37.658071 55.725961,37.658321
55.725609,37.658303 55.725374,37.658321 55.725609,37.658906
55.725309,37.659488 55.72511,37.658135 55.724571,37.657386
55.724922,37.657135 55.724873,37.65647 55.725274,37.655635
55.725828,37.655195 55.7265,37.655635 55.725927,37.654639
55.726496),(37.658321 55.725609,37.658906 55.725309,37.659488
55.72511,37.658906 55.725309,37.658321 55.725609))
> > >> search=# select isvalid(geometryFromText(the_geom));
> > >> NOTICE: IllegalArgumentException: degenerate ring (does not contain
3 distinct points)
> > >> ERROR: GEOS isvalid() threw an error!
> > >> search=# select isvalid(exteriorring(geometryFromText(the_geom)));
> > >> isvalid
> > >> t
> > >> (1 row)
> > >> search=# select isvalid(interiorringN(geometryFromText(the_geom),1));
> > >> isvalid
> > >> t
> > >> (1 row)
> > >> Any suggestions?
> > >> Thanks!
> > >> Sergey Karin
> > >What GEOS / PostGIS version are you using ?
> > >SELECT postgis_full_version();
> > >--strk;
> > search=# select postgis_full_version();
> > POSTGIS="0.9.0" GEOS="2.0.1" PROJ="Rel. 4.4.8, 3 May 2004" USE_STATS
DBPROC="0.0.1" RELPROC="0.0.1"
> > (1 row)
