[postgis-users] Converting ESRI Geodatabase
Steve Lehr
lehrs at erau.edu
Tue Nov 9 14:29:46 PST 2004
Paul:
Thanks that's the first LBO, any insight on the second Element LBO which
houses the actual text? I guess its an ESRI Elment Object within it
containing a Text Symbol?
Thanks
Steven Lehr
Assistant Professor
Freshmen Program
College of Engineering
Embry-Riddle Aeronautical University (LB159)
600 S. Clyde Morris Blvd.
Daytona Beach, FL 32114-3900
386-226-7740
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of Paul
Ramsey
Sent: Tuesday, November 09, 2004 3:55 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Converting ESRI Geodatabase
Apparently it is the same format as shape files use, so start w/ the
Shape file specification and work from there. Should be pretty easy.
P
Steve Lehr wrote:
> I'm trying to extract the point/annotation information from an ESRI
> Geodatabase stored in MS Access.
> Does someone have the format for the LBO so that I can unpack the data and
> extract the x,y,angle, and text for labels/annotation.
> Thanks. Beer is on me if you have the answer :-)
> Steven Lehr
> Assistant Professor
> Freshmen Program
> 386-226-7740
> postgis-users mailing list
