[postgis-users] Massive Lidar Dataset Datatype Suggestions?
collin collin at socrates.berkeley.edu
Sat Nov 13 14:39:47 PST 2004
I agree that post-production DEM analysis should be in raster.  However
what we are doing is processing the raw laser points to generate the
raster grids.
Interpolating the raw data into raster without categorization produces
significant information loss.
Most of our effort right now is working on algorithms to categorize the
points into ground, middle, and canopy.  The ground & canopy points are
then exported and interpolated into grids (1x1 meter resolution).
Collin
Robert W. Burgholzer wrote:
> Perhaps I've weighed in on this before, so excuse me if I sound like a
> broken record. This situation appears to me to be best suited to a
> raster analysis. I would like to see (help to develop) this type of
> functionality in postgis.
>  From what I have seen, there are no raster components to the OGC specs
> for SQL. IMHO, this is a logical next step, and also one that could be
> potentially very powerful for the integration of environmental data such
> as the lidar elevations and so forth. Of course, with anything
> worthwhile, this will require some time and expertise - something I am
> more than willing to be involved in. If anyone could comment on some
> documents that might point one to how to outline a raster specification
> for SQL, that would be great.
> A potential set of components:
> - Raster as rectangular feature
> - Geometry column holds boundaries of raster rectangle
> - raster data as file pointer or large data object (BLOB?)
> Rob
> At 12:34 PM 11/13/2004 -0800, you wrote:
>> Greetings all,
>> I asked some questions about massive point datasets in April, before
>> the implementation of LWGEOM. Then I fell off the face of the earth
>> for a while.  Know I'm back working on this issue again and would love
>> some input.
>> I have a LIDAR dataset of 473 million points with 2 point geometries
>> (first & last returns), timestamp and 2 laser intensity returns
>> (integer).
>> I am trying to figure the best setup for storing, extracting and
>> processing this dataset.  btw, it is a smallish dataset. We will be
>> processing 2 billion+ point projects in the near future.
>> Currently I compiled & installed postgresql 8.0 beta 4, with postgis
>> 0.9 release, geos 2.0.1, and proj 4.  This is on Fedora Core 2, smp
>> 733mhz, 1GB ram, 160gb hdd Intellistation.
>> I am using HWGEOM, with WKT right now and managed to create a table
>> with  oid & the_geom for one point per return.
>> The upload took 48 hours and is roughly 85GB.
>> The GiST indexing took ~80 hours and is ~35GB.
>> This is obviously non-optimal considering we now have WKB and LWGEOM
>> to play with.  I couldn't get LWGEOM to install properly from the cvs
>> extract, which is why I reverted to the 0.9 version.
>> So, any suggestions on how to get the full 9-column dataset uploaded
>> with a more efficient data structure?  (note: current machine is just
>> a test machine. Production will have a LOT more drivespace).
>> Also, I intend to perform a fair amount of point processing inside the
>> database using either plpgsql or java api.  Is this a bad idea?
>> Thanks for any input.
>> ________________
>> Collin Bode
>> GIS Informatics Researcher
>> Power Lab, Integrative Biology
>> University of California, Berkeley
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Robert Burgholzer
> Environmental Engineer
> MapTech Inc.
> phone: 804-869-3066
> http://www.maptech-inc.com/
________________
Collin Bode
