[postgis-users] Can you call shp2pgsql from a c program ?
Ethan Alpert ealpert at digitalglobe.com
Thu Nov 18 11:01:18 PST 2004
I'm not a cygwin person but I'm betting you need the absolute path to
the executable shp2pgsql.
-e
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
David.Jacques at CCRS.NRCan.gc.ca
Sent: Thursday, November 18, 2004 11:52 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Can you call shp2pgsql from a c program ?
I'm developing some data loading routines in C/C++.
I'm able to call PQexec() with success for selection, inserting, etc.
However loading shapefiledata is another question entirely. Is this even
possible ? Is this a matter of having a mappable cygwin drive visible ?
I should mention I am using MSVS.NET 7.0 compiler to
create win32 console apps (using ANSI c/c++ functionality only).
//get the .shp name from the unzipped file...
pShapeFileName = GetShapeFileName(pZipFileName);
//run the shape to postgis conversion program... sprintf(command,
"shp2pgsql -s 42304 %s xxmfirespots testdb >
%s.sql\n",pShapeFileName,pShapeFileName);
system(command);
'shp2pgsql' is not recognized as an internal or external
command,operable program or batch file. shp2pgsql -s 42304
mire2004323.shp xxmfirespots testdb > mfire2004323shp.sql
feedback appreciated.
David Jacques
postgis-users mailing list postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
