[postgis-users] trying to make
strk at refractions.net
Mon Nov 22 12:28:01 PST 2004
Could it be you compiled postgresql with SSL support ?
In that case I think you need to add appropriate linkage to
that library.
--strk;
On Mon, Nov 22, 2004 at 03:20:05PM -0500, János wrote:
> I untared postgis-0.9.0 into the contrib directory of the Postgresql
> 7.4.6 source. This is what I get when I run sudo make:
> Janos:/Volumes/Data/Downloads/postgresql-7.4.6/contrib/postgis-0.9.0
> janos$ sudo make
> Password:
> ./geos_version.sh /usr/local > postgis_geos_version.h
> gcc -no-cpp-precomp -O2 -fno-strict-aliasing -Wall -Wmissing-prototypes
> -Wmissing-declarations -g -fexceptions -I. -DFRONTEND
> -DSYSCONFDIR='"/Volums/Apps/pgsql/etc"' -DUSE_VERSION=74
> -DPOSTGIS_LIB_VERSION='"0.9.0"' -DPOSTGIS_SCRIPTS_VERSION='"0.0.1"'
> -I/usr/local/include -DUSE_GEOS -I/usr/local/include -DUSE_PROJ
> -DUSE_STATS -I../../src/include -c -o postgis_debug.o
> postgis_debug.c
> -DUSE_STATS -I../../src/include -c -o postgis_ops.o postgis_ops.c
> -DUSE_STATS -I../../src/include -c -o postgis_fn.o postgis_fn.c
> postgis_fn.c:3198: warning: no previous prototype for
> `postgis_scripts_released'
> -DUSE_STATS -I../../src/include -c -o postgis_inout.o
> postgis_inout.c
> -DUSE_STATS -I../../src/include -c -o postgis_proj.o postgis_proj.c
> -DUSE_STATS -I../../src/include -c -o postgis_chip.o postgis_chip.c
> -DUSE_STATS -I../../src/include -c -o postgis_transform.o
> postgis_transform.c
> -DUSE_STATS -I../../src/include -c -o postgis_svg.o postgis_svg.c
> -DUSE_STATS -I../../src/include -c -o postgis_gist_72.o
> postgis_gist_72.c
> -DUSE_STATS -I../../src/include -c -o postgis_estimate.o
> postgis_estimate.c
> -DUSE_STATS -I../../src/include -c -o postgis_geos.o postgis_geos.c
> postgis_geos.c:317: warning: `resize_ptrArrayType' defined but not used
> g++ -O2 -fno-strict-aliasing -Wall -Wmissing-prototypes
> -I/usr/local/include -DUSE_GEOS -I/usr/local/include -DUSE_PROJ -fPIC
> -I../../src/include -c -o postgis_geos_wrapper.o
> postgis_geos_wrapper.cpp
> cc1plus: warning: "-Wmissing-declarations" is valid for C/ObjC but not
> for C++
> -DUSE_STATS -I../../src/include -c -o postgis_algo.o postgis_algo.c
> ar crs libpostgis.a `lorder postgis_debug.o postgis_ops.o postgis_fn.o
> postgis_inout.o postgis_proj.o postgis_chip.o postgis_transform.o
> postgis_svg.o postgis_gist_72.o postgis_estimate.o postgis_geos.o
> postgis_geos_wrapper.o postgis_algo.o | tsort`
> tsort: cycle in data
> tsort: postgis_geos.o
> tsort: postgis_geos_wrapper.o
> tsort: postgis_fn.o
> tsort: postgis_inout.o
> ranlib libpostgis.a
> -DUSE_STATS -bundle postgis_debug.o postgis_ops.o postgis_fn.o
> postgis_geos_wrapper.o postgis_algo.o -L../../src/port -L../../src/port
> -lstdc++ -L/usr/local/lib -lgeos -L/usr/local/lib -lproj
> -bundle_loader ../../src/backend/postgres -o libpostgis.so.0.9
> ld: warning multiple definitions of symbol _translate
> postgis_fn.o definition of _translate in section (__TEXT,__text)
> ../../src/backend/postgres definition of _translate
> rm -f libpostgis.so.0
> ln -s libpostgis.so.0.9 libpostgis.so.0
> rm -f libpostgis.so
> cpp -P -traditional-cpp -DUSE_VERSION=74 postgis.sql.in | sed -e
> 's:@MODULE_FILENAME@:\$libdir/libpostgis.so.0.9:g;s:@POSTGIS_VERSION@:
> 0.9 USE_GEOS=1 USE_PROJ=1
> USE_STATS=1:g;s:@POSTGIS_SCRIPTS_VERSION@:0.0.1:g' > postgis.sql
> perl create_undef.pl postgis.sql 74 > postgis_undef.sql
> make -C loader
> gcc -no-cpp-precomp -g -I.. -I. -I../../../src/interfaces/libpq -O2
> -fno-strict-aliasing -Wall -Wmissing-prototypes -Wmissing-declarations
> -DFRONTEND -DSYSCONFDIR='"/Volums/Apps/pgsql/etc"' -DUSE_VERSION=73
> -I../../../src/include -c -o shpopen.o shpopen.c
> shpopen.c:176: warning: `rcsid' defined but not used
> -I../../../src/include -c -o dbfopen.o dbfopen.c
> dbfopen.c:200: warning: `rcsid' defined but not used
> -I../../../src/include -c -o getopt.o getopt.c
> getopt.c:115: warning: conflicting types for built-in function `strncmp'
> getopt.c:602: warning: no previous prototype for `getopt'
> -I../../../src/include -c -o shp2pgsql.o shp2pgsql.c
> shpopen.o dbfopen.o getopt.o shp2pgsql.o -L../../../src/port -o
> shp2pgsql
> -I../../../src/include -c -o pgsql2shp.o pgsql2shp.c
> pgsql2shp.c: In function `parse_commandline':
> pgsql2shp.c:2297: warning: implicit declaration of function `getopt'
> shpopen.o dbfopen.o getopt.o pgsql2shp.o
> -L../../../src/interfaces/libpq -lpq -L../../../src/port -o pgsql2shp
> ld: Undefined symbols:
> _SSL_pending
> _BIO_free
> _BIO_new_mem_buf
> _DH_check
> _DH_generate_parameters
> _DH_size
> _ERR_get_error
> _ERR_reason_error_string
> _EVP_PKEY_free
> _PEM_read_DHparams
> _PEM_read_PrivateKey
> _PEM_read_X509
> _PEM_read_bio_DHparams
> _SSL_CTX_ctrl
> _SSL_CTX_free
> _SSL_CTX_load_verify_locations
> _SSL_CTX_new
> _SSL_CTX_set_tmp_dh_callback
> _SSL_CTX_set_verify
> _SSL_CTX_set_verify_depth
> _SSL_connect
> _SSL_free
> _SSL_get_error
> _SSL_get_ex_data
> _SSL_get_peer_certificate
> _SSL_library_init
> _SSL_load_error_strings
> _SSL_new
> _SSL_read
> _SSL_set_ex_data
> _SSL_set_fd
> _SSL_shutdown
> _SSL_write
> _TLSv1_method
> _X509_NAME_get_text_by_NID
> _X509_NAME_oneline
> _X509_check_private_key
> _X509_free
> _X509_get_subject_name
> make[1]: *** [pgsql2shp] Error 1
> make: *** [loaderdumper] Error 2
> What is wrong here ?
> Thanks ahead,
> János
> ``Our enemies are innovative and resourceful, and so are we. They never
> stop thinking about new ways to harm our country and our people, and
> neither do we.'' -- George W. Bush
> postgis-users mailing list
