[postgis-users] routing using PostGIS
Eduardo Patto Kanegae
lists at webmapit.com.br
Fri Nov 26 04:12:21 PST 2004
You mean that PostGIS 1.0 will have this functions implemented in its C libpostgis.so ?
thanks
http://www.webmapit.com.br
ICQ: 303747254
Treinamento em UMN MapServer - http://www.webmapit.com.br/ptbr/?menuoption=mapserver
Fórum MapServer Brasil - http://mapserver.cttmar.univali.br/forum
***Fim da Mensagem / End of Message ***
On Fri, 26 Nov 2004 11:25:51 +0100, strk at refractions.net escreveu:
> De: strk at refractions.net
> Data: Fri, 26 Nov 2004 11:25:51 +0100
> Para: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
> Assunto: Re: [postgis-users] routing using PostGIS
> On Fri, Nov 26, 2004 at 08:22:17AM -0200, Eduardo Patto Kanegae wrote:
> > Hi folks,
> > I'm interesting on implementing Dijkstra algorithm into PostGIS/PostGreSQL using PL/PGSQL
> > Does anybody has experience with this algorithm ? I mean, does it have possible constraints that could avoid PL/PGSQL implementation?
> > cheers
> It'll be hell implementing it in PL/PGSQL.
> You don't have easy vertex access, you'd have to extract that info
> parsing WKT (or in the best case HEXWKB - with postgis-1.0).
> I suggest you do it in C using the new api found in CVS.
> --strk;
> > ICQ: 303747254
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
