[postgis-users] Error compiling geos 2.1.0 on Windows/MinGW
TECHER Jean David
davidtecher at yahoo.fr
Mon Nov 29 02:10:20 PST 2004
Hi
I tried to compil geos 2.1.0 on Windows XP using MinGW
I got this error
g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers -I../../source/headers/geos -I../../source/headers -DGEOS_VERSION=2.1.0 -g -O2 -MT Profiler.lo -MD -MP -MF .deps/Profiler.Tpo -c ../util/Profiler.cpp -DDLL_EXPORT -DPIC -o .libs/Profiler.o
../util/Profiler.cpp: In member function `void geos::Profile::start()':
../util/Profiler.cpp:36: `gettimeofday' undeclared (first use this function)
../util/Profiler.cpp:36: (Each undeclared identifier is reported only once for
each function it appears in.)
make[2]: *** [Profiler.lo] Error 1
make[2]: Leaving directory `/home/src-2004-11-26/geos-2.1.0/source/geom'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/src-2004-11-26/geos-2.1.0/source'
make: *** [all-recursive] Error 1
As I'm not a great C++ programer I saw that gettimeofday' is not in my sources from MinGW
On the Web , I found this code but not sure for his need
typedef struct _FILETIME {
unsigned long dwLowDateTime;
unsigned long dwHighDateTime;
} FILETIME;
void __stdcall GetSystemTimeAsFileTime(FILETIME*);
void gettimeofday(struct timeval* p, void* tz /* IGNORED */);
void gettimeofday(struct timeval* p, void* tz /* IGNORED */){
union {
long long ns100; /*time since 1 Jan 1601 in 100ns units */
FILETIME ft;
} _now;
GetSystemTimeAsFileTime( &(_now.ft) );
p->tv_usec=(long)((_now.ns100 / 10LL) % 1000000LL );
p->tv_sec= (long)((_now.ns100-(116444736000000000LL))/10000000LL);
return;
Putting it on Profiler.cpp work but make stopped for XMLTester.exe
Any Ideas???
TECHER Jean David
Responsable Informatique 01MAP
e-mail: davidtecher at yahoo.fr
site perso : http://techer.pascal.free.fr/postgis/
site pro: http://www.01map.com/download/
K-S:"The greatest trick the devil pulled off was convincing people he didn't exist"
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20041129/97cfbce3/attachment.html>
