[postgis-users] Error compiling geos 2.1.0 on Windows/MinGW
TECHER Jean David
davidtecher at yahoo.fr
Mon Nov 29 03:31:15 PST 2004
Hi strk;
1. TEST FOR GEOS 2.1.0
make and make install works fine for me.........OK
As I said to you from geos-2.1.0/source/headers/geos/profiler.h
I replace
#include <sys/time.h>
by this from this link http://mywebpage.netscape.com/yongweiwu/timeval.h.txt
I will make the tests for PG 8.0.0 b5/proj 4.4.9 and postgis CVS...just to
see if everything is OK
2. Contact - Author
>From http://mywebpage.netscape.com/yongweiwu/
mail: adah @sh163. net
TECHER Jean David
Responsable Informatique 01MAP
e-mail: davidtecher at yahoo.fr
site perso : http://techer.pascal.free.fr/postgis/
site pro: http://www.01map.com/download/
K-S:"The greatest trick the devil pulled off was convincing people he didn't
exist"
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Monday, November 29, 2004 12:18 PM
Subject: Re: [postgis-users] Error compiling geos 2.1.0 on Windows/MinGW
> On Mon, Nov 29, 2004 at 12:10:58PM +0100, TECHER Jean David wrote:
> > is it possiblr to try this???
> > instead of include <sys/time.h> if util/profiler.h ???
> Should work, do you know how to contact the author for copy
> permissions ?
> --strk;
> > TECHER Jean David
didn't exist"
> > From: TECHER Jean David
> > To: PostGIS Users Discussion
> > Sent: Monday, November 29, 2004 11:10 AM
> > Subject: [postgis-users] Error compiling geos 2.1.0 on Windows/MinGW
> > Hi
> > I tried to compil geos 2.1.0 on Windows XP using MinGW
> > I got this error
g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers -I../../source/headers/ge
os -I../../source/headers -DGEOS_VERSION=2.1.0 -g -O2 -MT
Profiler.lo -MD -MP -MF .deps/Profiler.Tpo -c
./util/Profiler.cpp -DDLL_EXPORT -DPIC -o .libs/Profiler.o
> > ../util/Profiler.cpp: In member function `void
geos::Profile::start()':
> > ../util/Profiler.cpp:36: `gettimeofday' undeclared (first use this
function)
> > ../util/Profiler.cpp:36: (Each undeclared identifier is reported only
once for
> > each function it appears in.)
> > make[2]: *** [Profiler.lo] Error 1
> > make[2]: Leaving directory
`/home/src-2004-11-26/geos-2.1.0/source/geom'
> > make[1]: *** [all-recursive] Error 1
> > make[1]: Leaving directory `/home/src-2004-11-26/geos-2.1.0/source'
> > make: *** [all-recursive] Error 1
> > As I'm not a great C++ programer I saw that gettimeofday' is not in
my sources from MinGW
> > On the Web , I found this code but not sure for his need
> > typedef struct _FILETIME {
> > unsigned long dwLowDateTime;
> > unsigned long dwHighDateTime;
> > } FILETIME;
> > void __stdcall GetSystemTimeAsFileTime(FILETIME*);
> > void gettimeofday(struct timeval* p, void* tz /* IGNORED */);
> > void gettimeofday(struct timeval* p, void* tz /* IGNORED */){
> > union {
> > long long ns100; /*time since 1 Jan 1601 in 100ns units */
> > FILETIME ft;
> > } _now;
> > GetSystemTimeAsFileTime( &(_now.ft) );
> > p->tv_usec=(long)((_now.ns100 / 10LL) % 1000000LL );
> > p->tv_sec=
(long)((_now.ns100-(116444736000000000LL))/10000000LL);
> > return;
> > Putting it on Profiler.cpp work but make stopped for XMLTester.exe
> > Any Ideas???
> > TECHER Jean David
didn't exist"
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
