[postgis-users] Can't compile Postgis 0.9.0 on Postgress 7.4.5.1(Cygwin)
strk at refractions.net strk at refractions.net
Mon Oct 4 00:46:37 PDT 2004
On Mon, Oct 04, 2004 at 10:34:34AM +0700, Januar V. Simarmata wrote:
> I found that it is already '<' character:
> #if GEOS_LAST_INTERFACE < 2
> How to fix it?
It's not a bug!
My guess was the '<' is not really a '<' but an equivalent-looking
char. Two things to check:
	1) Is it really a '<' ?
	2) Does you preprocessor accept that kind of expression ?
--strk;
> cheers,
> Jan
> ----- Original Message -----
> From: <strk at refractions.net>
> To: "'PostGIS Users Discussion'" <postgis-users at postgis.refractions.net>
> Sent: Sunday, October 03, 2004 11:00 PM
> Subject: Re: [postgis-users] Can't compile Postgis 0.9.0 on Postgress
> 7.4.5.1(Cygwin)
> > On Sun, Oct 03, 2004 at 09:15:14PM +0700, Januar V. Simarmata wrote:
> > > postgis_geos_wrapper.cpp:203:5: invalid character '\206' in #if
> > > postgis_geos_wrapper.cpp:245:5: invalid character '\206' in #if
> > > postgis_geos_wrapper.cpp:278:5: invalid character '\206' in #if
> > > postgis_geos_wrapper.cpp:363:5: invalid character '\206' in #if
> > > postgis_geos_wrapper.cpp:399:5: invalid character '\206' in #if
> > > postgis_geos_wrapper.cpp:437:5: invalid character '\206' in #if
> > > postgis_geos_wrapper.cpp:469:5: invalid character '\206' in #if
> > > postgis_geos_wrapper.cpp:533:5: invalid character '\206' in #if
> > > postgis_geos_wrapper.cpp:565:5: invalid character '\206' in #if
> > > postgis_geos_wrapper.cpp:1519:5: invalid character '\206' in #if
> > > postgis_geos_wrapper.cpp:1535:5: invalid character '\206' in #if
> > > make: *** [postgis_geos_wrapper.o] Error 1
> > Is it the '<' char ??
> > Can it be something changed it into a weird char ?
> > Check those line and make sure the '<' is actually an ascii '<'
> > (\074)
> > --strk;
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
