[postgis-users] Can't compile Postgis 0.9.0 onPostgress7.4.5.1(Cygwin)
Januar V. Simarmata
januar at web4yours.com
Mon Oct 4 21:27:47 PDT 2004
Hi Strk,
It seems that my platform support preprocessor:
$ cpp test
# 1 "test"
# 1 "<built-in>"
# 1 "<command line>"
# 1 "test"
less then 100
Needs help,
Jan
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Monday, October 04, 2004 6:59 PM
Subject: Re: [postgis-users] Can't compile Postgis 0.9.0
> On Mon, Oct 04, 2004 at 06:29:54PM +0700, Januar V. Simarmata wrote:
> > Hi Strk,
> > I am sure it is an environmental issue, not a code bug.
> > Anyway, I've looked at behind the "letter" and found that it is "3C".
That's
> > different with the ascii code you mentioned before.
> 3C is hex for \074 octal, which is a '<'.
> That's correct!
> > Other thing,
> > I don't understand very much about preprocessor. How to check this?
> > I am using:
> > $ gcc --version
> > gcc (GCC) 3.3.3 (cygwin special)
> > Copyright (C) 2003 Free Software Foundation, Inc.
> > This is free software; see the source for copying conditions. There is
NO
> > warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
> > $ make --version
> > GNU Make 3.80
> > Copyright (C) 2002 Free Software Foundation, Inc.
> > There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
> > PARTICULAR PURPOSE.
> > Needs you help,
> Edit a file 'test':
> #define NUMBER 10
> #if NUMBER < 100
> less then 100
> #else
> greater or equal 100
> #endif
> $ cpp test
> see the output.
> --strk;
> > Jan
> > From: <strk at refractions.net>
> > Sent: Monday, October 04, 2004 2:46 PM
> > Subject: Re: [postgis-users] Can't compile Postgis 0.9.0 on
> > > On Mon, Oct 04, 2004 at 10:34:34AM +0700, Januar V. Simarmata wrote:
> > > > I found that it is already '<' character:
> > > > #if GEOS_LAST_INTERFACE < 2
> > > > How to fix it?
> > > It's not a bug!
> > > My guess was the '<' is not really a '<' but an equivalent-looking
> > > char. Two things to check:
> > > 1) Is it really a '<' ?
> > > 2) Does you preprocessor accept that kind of expression ?
> > > --strk;
> > > > cheers,
> > > > Jan
> > > > To: "'PostGIS Users Discussion'"
> > > > Sent: Sunday, October 03, 2004 11:00 PM
Postgress
> > > > 7.4.5.1(Cygwin)
> > > > > On Sun, Oct 03, 2004 at 09:15:14PM +0700, Januar V. Simarmata
wrote:
> > > > > > postgis_geos_wrapper.cpp:203:5: invalid character '\206' in #if
> > > > > > postgis_geos_wrapper.cpp:245:5: invalid character '\206' in #if
> > > > > > postgis_geos_wrapper.cpp:278:5: invalid character '\206' in #if
> > > > > > postgis_geos_wrapper.cpp:363:5: invalid character '\206' in #if
> > > > > > postgis_geos_wrapper.cpp:399:5: invalid character '\206' in #if
> > > > > > postgis_geos_wrapper.cpp:437:5: invalid character '\206' in #if
> > > > > > postgis_geos_wrapper.cpp:469:5: invalid character '\206' in #if
> > > > > > postgis_geos_wrapper.cpp:533:5: invalid character '\206' in #if
> > > > > > postgis_geos_wrapper.cpp:565:5: invalid character '\206' in #if
> > > > > > postgis_geos_wrapper.cpp:1519:5: invalid character '\206' in #if
> > > > > > postgis_geos_wrapper.cpp:1535:5: invalid character '\206' in #if
> > > > > > make: *** [postgis_geos_wrapper.o] Error 1
> > > > > Is it the '<' char ??
> > > > > Can it be something changed it into a weird char ?
> > > > > Check those line and make sure the '<' is actually an ascii '<'
> > > > > (\074)
> > > > > --strk;
