[postgis-users] 3D geometry objects
Ron Mayer
rm_postgis at cheapcomplexdevices.com
Tue Oct 5 20:15:50 PDT 2004
I was mildly surprised to see that the Z coordinate doesn't work
the way I was expecting. In particular, the Z axis seems to be ignored
when comparing bounding boxes, and geomunion seems to flatten my points.
I don't actually need such features to work, but was kinda surprised to
see no obvious reference in the postgis manual so it made me wonder if I
have a configuration problem here.
I am using postgis-0.8.2 and postgresql-7.4.3 on SuSE 9 and a
postgis-0.8.2 and postgresql-8.0.0beta2.
Example queries of results that surprised me follow.
Thanks,
Ron
fl=# select 'BOX3D(-1 -1 -1, 1 1 -2)'::box3d && 'BOX3D(-1 -1 1, 1 1 2)'::box3d;
?column?
t
(1 row)
fl=# select intersects('BOX3D(-1 -1 -1, 1 1 -2)'::box3d, 'BOX3D(-1 -1 1, 1 1 2)'::box3d);
intersects
t
(1 row)
fl=# select geomunion(a) from (
select (GeomFromText('POINT(-1 -1 -1)',-1)) as a
union
select (GeomFromText('POINT(-1 -1 -0)',-1)) as a
) as a;
geomunion
SRID=-1;POINT(-1 -1 1.7e-308)
(1 row)
union
select (GeomFromText('POINT(-1 -0 -0)',-1)) as a
) as a;
geomunion
SRID=-1;MULTIPOINT(-1 -1 1.7e-308,-1 -0 1.7e-308)
(1 row)
########## more version info ###########
fl=# -- [on the windows machine]
fl=# select name,setting,postgis_full_version() from pg_settings where name = 'server_version';
name | setting | postgis_full_version
server_version | 8.0.0beta2 | POSTGIS="0.8.2" GEOS="2.0.0" PROJ="Rel. 4.4.8, 3 May 2004" USE_STATS DBPROC="0.0.1" RELPROC="0.0.1"
(1 row)
fl=# -- [on the SuSE machine (postgis_full_version doesn't exist)]
fl=# select name,setting,postgis_version() from pg_settings where name = 'server_version';
name | setting | postgis_version
server_version | 7.4.3 | 0.8 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
