[postgis-users] Cross sectional slice of 3d features
strk at refractions.net
Wed Oct 6 23:21:44 PDT 2004
David, I suggest you get a CVS snapshot of postgis and get
used with the new API. I'll be happy to help.
--strk;
On Wed, Oct 06, 2004 at 12:51:10PM -0500, David Bitner wrote:
> Does anyone know how best to go about creating some functions to work with
> creating a cross-sectional slice of a 3d feature set. I have a set of 3d
> lines that I would like to draw an intersecting line over. Using
> Intersection() I can get the geometry of the points where the lines
> intersect. What I would like is a result geometry with the Y-coord as the
> elevation of the points of intersection and the X-coord as the distance
> along the line where the intersection was (to make a penetration diagram).
> I would also like to be able to get the average z value of the intersection
> set. As always, any help is greatly appreciated.
> David
> postgis-users mailing list
