I have a wkb_geometry column now in PostGIS that are all LINESTRINGs. How can I either dynamically or statically convert them to POLYGONs? A single geometry columns holds both now, all as LINESTRINGs, but I can separate the POLYGONs into a separate column or table if needed. Thanks!! Tim
