[postgis-users] Performanceproblems
strk at refractions.net
Tue Oct 12 02:56:43 PDT 2004
Werdin,
First of all you should split your timings
between && and distance_spheroid() runtimes.
Note that your old query did not compute distances,
but just the equivalent of the && operator.
Compare the two w/out distance_spheroid involved.
Also compare difference bwteen distance_spheroid()
and distance().
If distance() is much faster (should be) you might transform
you data to isometric projections (since you already split
by zones).
--strk;
On Tue, Oct 12, 2004 at 09:59:45AM +0200, Werdin Jens wrote:
> Hello,
> I have a performance problem with PostGis. The Database has 11 million
> entries which have coordinates in WGS84 and a timestamp with TS. If I used a
> normal postgres-table with latitude and longitude as a coloum a an index
> over time,lat,long it took not 2 secs for the query "Select * from table
> where time between and lat between and long between..." now I transformed it
> to postgis because I want the result sorted by distance_spheroid(). The
> Table now looks like id / time / POINT(srid=4326). I created the Index,
> updated geometry stats and vacuumed like described in the manual.
> I use the query select *, distance_spheroid from table where geopoint &&
> setsrid(box3d) and time between 2 and 3 order by distance_spheroid.
> This query now takes more than 15 mins.
> The result should have 100 entries (average) and up to 3000 entries (max).
> Do I have to change settings in the database or takes the distance_spheroid
> so much time or is my query not good or is it better to use an index on
> time?
> Thanks in advance
> Jens
> postgis-users mailing list
