[postgis-users] Quick Note for XP Home UsersandWin32PostgreSQL8.0 beta 1 installer
TECHER Jean David
davidtecher at yahoo.fr
Tue Oct 12 05:05:47 PDT 2004
Hi Mark
Did you made some tests such as Intersects(), interserction, area(),
geomunion() jus to see
fisrt test should be to try PointOnSurface()...
if everything is OK.... :-)
TECHER Jean David
Responsable Informatique 01MAP
e-mail: davidtecher at yahoo.fr
site: http://techer.pascal.free.fr/postgis/
----- Original Message -----
From: "Mark Cave-Ayland" <m.cave-ayland at webbased.co.uk>
To: "'PostGIS Users Discussion'" <postgis-users at postgis.refractions.net>
Sent: Tuesday, October 12, 2004 12:17 PM
Subject: RE: [postgis-users] Quick Note for XP Home
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of strk at refractions.net
> Sent: 06 October 2004 12:51
> To: 'PostGIS Users Discussion'
> Subject: Re: [postgis-users] Quick Note for XP Home Users
> On Wed, Oct 06, 2004 at 12:40:33PM +0100, Mark Cave-Ayland wrote:
> (cuts)
> > I think when Dave (Blasby) looked into this to begin with
> it was a bug
> > in glibc.... Does anyone know whether this has been fixed in the
> > version of gcc supplied with MingW? If someone could post
> to the list
> > an SQL command that throws a GEOS exception then it would
> be good for
> > someone to test this....
> select geosnoop('POLYGON((0 0, 1 1, 0 0))');
> --strk;
OK, I've just compiled PostgreSQL 8.0b3/PostGIS 0.9 CVS branch WITHOUT using
LDFLAGS=-lstdc++ under Win32 and here are the results:
Welcome to psql 8.0.0beta3, the PostgreSQL interactive terminal.
Type: \copyright for distribution terms
\h for help with SQL commands
\? for help with psql commands
\g or terminate with semicolon to execute query
\q to quit
Warning: Console codepage (850) differs from windows codepage (1252)
8-bit characters will not work correctly. See PostgreSQL
documentation "Installation on Windows" for details.
test=# \d
List of relations
Schema | Name | Type | Owner
public | geometry_columns | table | postgres
public | spatial_ref_sys | table | postgres
(2 rows)
test=# select geosnoop('POLYGON((0 0, 1 1, 0 0))');
NOTICE: IllegalArgumentException: Number of points must be 0 or >3
ERROR: Couldnt convert the postgis geometry to GEOS!
test=#
This is great news as the backend didn't die. It means that it should be
possible to distribute just the extra PostGIS DLL/SQL files as a stand-alone
installer (as done at http://dcmms.sourceforge.net/postgis_installer.php)
without requiring a specially compiled PostgreSQL to go with it.
FWIW this was again under MinGW 3.1.0-1 and MSYS 1.0.10 (gcc 3.2.3).
Kind regards,
Mark.
WebBased Ltd
South West Technology Centre
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 791021
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
