[postgis-users] ERROR: GEOS union() threw an error!
strk at refractions.net strk at refractions.net
Tue Oct 12 11:39:22 PDT 2004
On Tue, Oct 12, 2004 at 12:08:58PM -0600, Ethan Alpert wrote:
> Why does the following throw an error?
Run issimple() on them as the first thing when facing these problems.
If all input are simple try newer GEOS (if running GEOS-1.0.0).
--strk;
> Error Msg:
> spatialdb=> select geomunion(the_geom) from snaps where
> stripid='101001000351ED00';
> NOTICE:  TopologyException: no outgoing dirEdge found (127.169,38.0556)
> Here's the Geometries:
> spatialdb=> select catfrag, stripid,AsText(the_geom) from snaps where
> -[ RECORD 1
> catfrag | 101001000351ED013757480
> stripid | 101001000351ED00
> astext  | POLYGON((126.9405 38.2139166666667,127.171686111111
> 38.2092055555556,127.168805555556 38.0372638888889,126.941602777778
> 38.0439083333333,126.9405 38.2139166666667))
> -[ RECORD 2
> catfrag | 101001000351ED022377883
> astext  | POLYGON((126.941597222222 38.0758111111111,127.169166666667
> 38.0698111111111,127.16855 37.9064833333333,126.942888888889
> 37.9145527777778,126.941597222222 38.0758111111111))
> -[ RECORD 3
> catfrag | 101001000351ED023757478
> Here's where it get's odd:
> catfrag='101001000351ED022377883' or catfrag='101001000351ED023757478'
> or catfrag='101001000351ED013757480';
> -[ RECORD 1
> geomunion | SRID=4326;POLYGON((126.9405
> 38.2139166666667,127.171686111111 38.2092055555556,127.169113088743
> 38.0556206842087,127.16855 37.9064833333333,126.942888888889
> 37.9145527777778,126.941852819554 38.0439010209725,126.941602777778
> Why does this work when I manually query on the tables index? Note two
> of the geometries are the same. If I delete either the geomunion works.
> The geometries are all SRID=4326
> I'm running postgres 7.4.3 and postgis 0.8.2
> Time for an upgrade? Very odd behavior...IMHO
> postgis-users mailing list
