[postgis-users] ERROR: GEOS union() threw an error!
strk at refractions.net
Tue Oct 12 12:08:23 PDT 2004
On Tue, Oct 12, 2004 at 12:59:00PM -0600, Ethan Alpert wrote:
> Well issimple returns t for all.
> spatialdb=> select issimple(the_geom) from snaps where stripid
> ='101001000351ED00';
> issimple
> t
> t
> t
> (3 rows)
> I do have geos 1.0 so I'll try that. Does upgrading geo require me to
> rebuild postgis?
Unfortunately YES.
--strk;
> -e
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Sent: Tuesday, October 12, 2004 12:39 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] ERROR: GEOS union() threw an error!
> On Tue, Oct 12, 2004 at 12:08:58PM -0600, Ethan Alpert wrote:
> > Why does the following throw an error?
> Run issimple() on them as the first thing when facing these problems. If
> all input are simple try newer GEOS (if running GEOS-1.0.0). --strk;
> > Error Msg:
> > spatialdb=> select geomunion(the_geom) from snaps where
> > stripid='101001000351ED00';
> > NOTICE: TopologyException: no outgoing dirEdge found
> > (127.169,38.0556)
> > Here's the Geometries:
> > spatialdb=> select catfrag, stripid,AsText(the_geom) from snaps where
> > stripid='101001000351ED00'; -[ RECORD 1
> > catfrag | 101001000351ED013757480
> > stripid | 101001000351ED00
> > astext | POLYGON((126.9405 38.2139166666667,127.171686111111
> > 38.2092055555556,127.168805555556 38.0372638888889,126.941602777778
> > 38.0439083333333,126.9405 38.2139166666667))
> > -[ RECORD 2
> > catfrag | 101001000351ED022377883
> > astext | POLYGON((126.941597222222 38.0758111111111,127.169166666667
> > 38.0698111111111,127.16855 37.9064833333333,126.942888888889
> > 37.9145527777778,126.941597222222 38.0758111111111))
> > -[ RECORD 3
> > catfrag | 101001000351ED023757478
> > Here's where it get's odd:
> > catfrag='101001000351ED022377883' or catfrag='101001000351ED023757478'
> > or catfrag='101001000351ED013757480';
> > -[ RECORD 1
> > geomunion | SRID=4326;POLYGON((126.9405
> > 38.2139166666667,127.171686111111 38.2092055555556,127.169113088743
> > 38.0556206842087,127.16855 37.9064833333333,126.942888888889
> > 37.9145527777778,126.941852819554 38.0439010209725,126.941602777778
> > Why does this work when I manually query on the tables index? Note two
> > of the geometries are the same. If I delete either the geomunion
> > works. The geometries are all SRID=4326
> > I'm running postgres 7.4.3 and postgis 0.8.2
> > Time for an upgrade? Very odd behavior...IMHO
> > postgis-users mailing list postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
