[postgis-users] Postgis upgrade instrucitons
strk at refractions.net strk at refractions.net
Tue Oct 12 12:38:20 PDT 2004
On Tue, Oct 12, 2004 at 01:30:07PM -0600, Ethan Alpert wrote:
> Ack!! Are you kidding me? I have a 100 million tuple DB I've built It
> took 20+hours to ingest. Is this really the ONLY way??
Not *really*.
In postgis-0.9.x there is a postgis_restore.pl script
which should make life easier.
- pg_dump -Fc olddb
- postgis_restore.pl
.. read synopsis ..
--strk;
PS: let me know how it went.
> UPGRADING:
> Upgrading PostGIS can be tricky, because the underlying C libraries
> which
> support the object types and geometries may have changed between
> versions.
> To avoid problems when upgrading, you will have to dump all the tables
> in your database, destroy the database, create a new one, add the
> PL/pgSQL
> language, upload the new postgis.sql file, then upload your database
> dump:
>   pg_dump -t "*" -f dumpfile.sql yourdatabase
>   dropdb yourdatabase
>   createdb yourdatabase
>   createlang plpgsql yourdatabase
>   psql -f postgis.sql -d yourdatabase
>   psql -f dumpfile.sql -d yourdatabase
>   vacuumdb -z yourdatabase
> postgis-users mailing list
