[postgis-users] AsSVG() and precision control
strk at refractions.net
Fri Oct 15 01:49:18 PDT 2004
On Thu, Oct 14, 2004 at 12:26:44PM +0200, Klaus Foerster wrote:
> >Your patch does not do what reported:
> >Precision defaults to 15, so you need to give it an explicit negative
> >number for the %g to take effect. Default would be 0 padded numbers.
> sorry, forgot about that - http://svg.cc/pg/assvg/assvg-0.5.1.patch solves
> that issue by setting default precision to -1 and using %.15g or %.*f
> accordingly.
I don't like this either.
Maybe we should always use %f and *manually* remove trailing zeros.
What do you think ?
--strk;
> >What I see is that the problem only arises for relative moves, where
> >number of significant digits wants to be different between absolute
> >and relative values.
> well, absolute notation might be affected as well. what about a coordinate
> pair like 241034.194490223,5610355.30134846 ? if you reduce output to seven
> digits you start mixing coordinate precision as x-coordinates originally
> have 6,
> and y-coords 7 digits to the left - 241034.2 -5610355 would be the result.
> >A proposal I can make is that:
> > - On "absolute" are requested all values will have 'precision'
> > - On "relative" way initial (absolute) values will have 15
> > significant digits, and relative values will have 'precision'
> > number of significant digits.
> >Do you think this would solve the problem ?
> i think absolute and relative notation should be treated the same way.
> please give
> my latest patch a try - i do think it now does what i intended to
> accomplish ;-)
> i've also updated http://svg.cc/pg/assvg/1_output.txt to reflect the change.
> klaus
> O-.
> /_ )
> | (U
> klaus* /|
> postgis-users mailing list
