[postgis-users] select asSVG(the_geom) || 'mytext' from mytable -- does not work
Jorg Heymans jh at domek.be
Fri Oct 15 03:46:30 PDT 2004
Above construct does not work because asSVG seems to tag a newline at
the end of it's output.
Following works:
select substring(asSVG(the_geom), 0, length(asSVG(the_geom))-1)
Thoughts?
Jorg Heymans
