[postgis-users] Calculating the area of overlapping polygons
Brent Wood
pcreso at pcreso.com
Sun Oct 17 16:50:32 PDT 2004
Hopefully someone can check my thinking on this as a spatial overlay analysis
using PostGIS.....
Data:
All in a Polar Stereographic projection which is close enough to an equal area
projection, units are meters.
table 1: 20,000,000 points with a depth attribute
table 2: grid of 50,000 cells (polygons) covering the region of interest, with
attrs of the min, max & avg depth of all the depth points in table1
which lie within each cell.
table 3: polygons describing sea-ice densities for required week within the
area.
Problem:
To determine the total area within this region for a given week, where the
depth is within a specified range and the sea-ice density below a specified
percentage.
Proposed solution:
Select the total area of intersecting cells where the avg depth is inside the
range & they intersect with the appropriate ice density polygons:
SQL1="select sum(area2d($GRID_TAB.the_geom))/1000000
from $GRID_TAB,
$ICE_TAB
where avg_depth <= -$MIN_DEPTH
and avg_depth > -$MAX_DEPTH
and substring(icecode from 3 for 2) < $ICECODE
and $GRID_TAB.the_geom && $ICE_TAB.the_geom
and intersects($GRID_TAB.the_geom, $ICE_TAB.the_geom);"
Issue: this expands the area estimate by including all the area from cells
which are partially outside the ice density polygons. So:
Select half the total area of the cells lying on the ice polygon boundaries:
SQL2="select sum(area2d($GRID_TAB.the_geom))/2000000
from $GRID_TAB,
$ICE_TAB
and overlaps($GRID_TAB.the_geom, $ICE_TAB.the_geom);"
Subtract the last from the first to get a reasonable answer, assuming that
about 1/2 the area of cells on the boundary is inside the polygons.
Given the inaccuracies of both the ice cover & depth data, I don't expect an
accurate answer, just a reasonable estimate.
If I've got this horribly wrong somewhere, can someone point me in the right
direction?
Do the intersect & overlap functions do what I want in this context?
Any tips on optimising the queries?
Thanks
Brent Wood
