[postgis-users] postgis.sql giving error on libgeos
David Bitner
bitner at macnoise.com
Tue Oct 26 10:40:57 PDT 2004
Alright, I'm getting there bit by bit. Cpp was out of my path, that solved
that problem. Now when I run postgis.sql, I get the following error:
psql:postgis.sql:47: NOTICE: type "histogram2d" is not yet defined
DETAIL: Creating a shell type definition.
psql:postgis.sql:47: ERROR: could not load library
"/usr/local/pgsql/lib/libpostgis.so.0.9": ld.so.1:
/usr/local/pgsql/bin/postmaster: fatal: libgeos.so.2: open failed: No such
file or directory
When I do an ldd on libpostgis.so.0.9, it finds all the libraries it needs
there. libgeos.so.2 is located where I designated in the Makefile.
One of these days, I'll get up and running...
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of Paul
Ramsey
Sent: Monday, October 25, 2004 4:06 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Zero Length postgis.sql on Make
Check the command that the Makefile is running to generate the .sql file.
Decompose it into bits and run the bits at the command line. One of the bits
is failing you (probably the cpp bit, but one never knows).
Paul
Quoting David Bitner <bitner at macnoise.com>:
> After running into problems with geos_version.sh that I got past with the
> help of strk at refractions, I am now getting a zero length postgis.sql
file
> with no errors coming from gmake -- other utilities work fine (ie
> shp2pgsql).
> I am compiling PostGIS 0.9.0 with Geos 2.0.0 (binary from
CSW/blastwave.org)
> on Solaris 9 (x86).
> Has anyone ever run into this problem before? Any hints about how to fix?
> David
> postgis-users mailing list
