RES: [postgis-users] Transform Points to Line
Gustavo Oliveira
gustavo.oliveira at 3WT.com.br
Thu Oct 28 06:03:14 PDT 2004
Isn't there another way to convert?
Something like GeometryFromText('LINESTRING(200509.7414
7564876.6272,201884.7341 7563144.9198)', -1)
The statement above I have strings and so I can make a line, but if I have
points instead of strings?
[]s
-----Mensagem original-----
De: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]Em nome de
strk at refractions.net
Enviada em: quinta-feira, 28 de outubro de 2004 07:27
Para: PostGIS Users Discussion
Cc: Paul Ramsey
Assunto: Re: [postgis-users] Transform Points to Line
Gustavo, just a note to warn you that postgis HEAD branch is
still under development (well.. this is tautologic).
I've just committed a new function so you can do:
SELECT makeline(esquina1.node, esquina2.node);
More constructors/editors are to come, but testing the
CVS version is an hard task as often you'll need to dump/restore
your database until the code gets to a stable state.
A dump/restore process will be needed for the upcoming 1.0.0 release
anyway as internal postgis structures has changed (optimized).
--strk;
On Thu, Oct 28, 2004 at 09:51:24AM +0200, strk at refractions.net wrote:
> On Wed, Oct 27, 2004 at 07:26:59PM -0200, Gustavo Oliveira wrote:
> > How can I tranform two points in a line?
> > I am trying something like that:
> > SELECT transform('LSEG((' || (esquina1.node)|| ', ' || (esquina2.node)
> > '))'::geometry)
> > FROM geo_rua arco, geo_esquina esquina1, geo_esquina esquina2
> > WHERE arco.idesqini = esquina1.id AND arco.idesqfim = esquina2.id;
> > At this statment esquina1.node and esquina2.node are columns which the
type
> > is point. I tried some variations of this, but all of them failed.
> With Postgis from the HEAD branch of CVS you can do the following:
> SELECT LineFromMultipoint(Collect(esquina1.node, esquina2.node));
> --strk;
> > Gustavo Borges de Oliveira
> > PIPE - FAPESP
> > 3WT - Wireless Web World Tech
> > tel: +55 16 3371-4343
> > fax: +55 16 3371-9847
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
