[postgis-users] Problems using buffer() and operador &&
strk at refractions.net
Thu Oct 28 08:41:09 PDT 2004
Gustavo, the LSEG type has nothing to do with postgis.
Postgis defines its own datatype, which is GEOMETRY.
There are currently no casts between postgresql geometric types
and postgis geometry type.
--strk;
On Thu, Oct 28, 2004 at 12:38:18PM -0200, Gustavo Oliveira wrote:
> I have a problem when trying to use && operator with buffer().
> I tried something like this:
> ae=# SELECT arco
> ae-# FROM vw_arcos
> ae-# WHERE BUFFER (GeometryFromText('LINESTRING(200509.7414
> 7564876.6272,201884.7341 7563144.9198)', -1), CAST (1000.01 as double
> precision)) && caminho;
> ERROR: operator does not exist: geometry && lseg
> HINT: No operator matches the given name and argument type(s). You may need
> to add explicit type casts.
> and like this one:
> ae=# SELECT arco
> ae-# FROM vw_arcos
> precision)) && caminho::geometry;
> ERROR: cannot cast type lseg to geometry
> I tried the same statements with ~ operator but the errors are the same.
> Caminho is a lseg type as you can see:
> arco | sentido | custo | caminho
> 1 | 0 | 81.2678 |
> [(201781.9537,7565503.6469),(201758.1738,7565425.9361)]
> 2 | 0 | 26.8538 |
> [(201758.1738,7565425.9361),(201769.1282,7565401.4182)]
> 4 | 0 | 109.652 |
> [(198967.4184,7561052.1535),(199047.7745,7561126.7623)]
> 5 | 0 | 20.5885 |
> [(199047.7745,7561126.7623),(199033.7658,7561141.8501)]
> 23 | 2 | 98.9721 |
> [(201014.4548,7561980.7571),(201078.5089,7561905.3081)]
> Could someone help me?
> []s
> Gustavo Borges de Oliveira
> PIPE - FAPESP
> 3WT - Wireless Web World Tech
> gustavo.oliveira at 3WT.com.br
> tel: +55 16 3371-4343
> fax: +55 16 3371-9847
> postgis-users mailing list
