[postgis-users] Help with spatial query (bug??)
Brent Wood
pcreso at pcreso.com
Tue Apr 5 22:38:55 PDT 2005
--- Carl Anderson <carl.anderson at vadose.org> wrote:
Thanks Carl.
Apologies for the length of this post, but I can't see why what I think is
effectively the same query returns two different results.
My problem turned out to be that a linestring with 2 points does not intersect
with (or relate to) the polygon containing it if the startpoint = endpoint. So
some 10000 records with 0 length lines disappeared from the join.
I'm not sure if this constitutes a bug or not (I'm using v0.8 & can't change
that easily)
All the linestrings in this data subset have 2 points.
Each of the two points is the same, so the lines are zero length.
Each cell is a lat/long square, so the bounding box is the actual polygon.
(In the main dataset, where non-zero length lines are present, the queries
appear to work correctly for non-zero length linestrings)
Query one:
psql $DB -c "select t.event_key,
c.cell_id,
x(startpoint(t.the_geom)),
y(startpoint(t.the_geom)),
c.the_geom
from chat_cells3 c,
test_junk t
where c.the_geom && t.the_geom;"
The output shows lines on the boundary of cells, with all the cells being
identified which touch or contain the line (point). A line(point) on the vertex
of four neighbouring cells gets 4 records returned.
event_key | cell_id | x | y |
the_geom
13683355 | 3553 | 175.5 | -44.2 | SRID=4326;POLYGON((175.45
-44.25,175.45 -44.2,175.5 -44.2,175.5 -44.25,175.45 -44.25))
13683355 | 3554 | 175.5 | -44.2 | SRID=4326;POLYGON((175.45
-44.2,175.45 -44.15,175.5 -44.15,175.5 -44.2,175.45 -44.2))
13683355 | 3625 | 175.5 | -44.2 | SRID=4326;POLYGON((175.5
-44.25,175.5 -44.2,175.55 -44.2,175.55 -44.25,175.5 -44.25))
13683355 | 3626 | 175.5 | -44.2 | SRID=4326;POLYGON((175.5
-44.2,175.5 -44.15,175.55 -44.15,175.55 -44.2,175.5 -44.2))
13677419 | 8186 | 178.68333 | -42.9833 | SRID=4326;POLYGON((178.65
-43,178.65 -42.95,178.7 -42.95,178.7 -43,178.65 -43))
12583686 | 2910 | 175.01667 | -43.9833 | SRID=4326;POLYGON((175 -44,175
-43.95,175.05 -43.95,175.05 -44,175 -44))
12578235 | 3198 | 175.23333 | -43.95 | SRID=4326;POLYGON((175.2
-44,175.2 -43.95,175.25 -43.95,175.25 -44,175.2 -44))
12578235 | 3199 | 175.23333 | -43.95 | SRID=4326;POLYGON((175.2
-43.95,175.2 -43.9,175.25 -43.9,175.25 -43.95,175.2 -43.95))
12497906 | 12481 | 181.65 | -44.2 | SRID=4326;POLYGON((181.65
-44.25,181.65 -44.2,181.7 -44.2,181.7 -44.25,181.65 -44.25))
12497906 | 12482 | 181.65 | -44.2 | SRID=4326;POLYGON((181.65
-44.2,181.65 -44.15,181.7 -44.15,181.7 -44.2,181.65 -44.2))
12497906 | 12409 | 181.65 | -44.2 | SRID=4326;POLYGON((181.6
-44.25,181.6 -44.2,181.65 -44.2,181.65 -44.25,181.6 -44.25))
12497906 | 12410 | 181.65 | -44.2 | SRID=4326;POLYGON((181.6
-44.2,181.6 -44.15,181.65 -44.15,181.65 -44.2,181.6 -44.2))
12497919 | 3270 | 175.26667 | -43.95 | SRID=4326;POLYGON((175.25
-44,175.25 -43.95,175.3 -43.95,175.3 -44,175.25 -44))
12497919 | 3271 | 175.26667 | -43.95 | SRID=4326;POLYGON((175.25
-43.95,175.25 -43.9,175.3 -43.9,175.3 -43.95,175.25 -43.95))
12497936 | 2841 | 174.98333 | -43.8333 | SRID=4326;POLYGON((174.95
-43.85,174.95 -43.8,175 -43.8,175 -43.85,174.95 -43.85))
12497956 | 4856 | 176.38333 | -43.8666 | SRID=4326;POLYGON((176.35
-43.9,176.35 -43.85,176.4 -43.85,176.4 -43.9,176.35 -43.9))
(16 rows)
the second query uses not disjoint, which with this data, I understand should
give the same result. In fact only 2 records are returned. Same if I use
intersects, relate, add in an "or touches" etc.
psql $DB -c "select event_key,
c.cell_id,
c.the_geom
from chat_cells3 c,
test_junk t
and not disjoint(t.the_geom, c.the_geom);"
the_geom
13683355 | 3626 | 175.5 | -44.2 | SRID=4326;POLYGON((175.5 -44.2,175.5
12497906 | 12482 | 181.65 | -44.2 | SRID=4326;POLYGON((181.65 -44.2,181.65
(2 rows)
I can't see why I get two different results???
I guess the simple fix is to move the (or add a new) endpoint some tiny
distance from the startpoint to create a line of non-zero length.
Is there a (relatively) simple way to do this in PostGIS v0.8?
Thanks again,
Brent Wood
> Brent Wood wrote:
> >I'm trying to make sense of the various spatial operators. I need to join a
> >table of cells to a table of lines, to create a table where there is a
> record
> >for each case where a line passes entirely or partially through a cell.
> >Looking at the OGC specs was a bit of help, but can anyone explain the
> >difference between the intersects, overlaps & crosses functions:
> >ie:
> >select
> >where
> > lines.geom && cell.geom and
> ><one of>
> > intersects(lines.geom, cell.geom)
> > overlaps(lines.geom, cell.geom)
> > crosses(lines.geom, cells.geom)
> >I figure I should be using crosses for this query, but don't undertand the
> >distinction between these.
> L - references the Line geometry
> A - references the cell, Polygon (area) geometry
> intersects (L,A) - line and polygon (cell) touch or overlay in any way
> overlaps (L,A) - is not defined for a line vs polygon test
> crosses (L,A) - line is part in and part out of the polygon, but not
> wholly inside
> within (L,A) - the line is wholly inside the polygon
> contains (A,L) - the line is wholly inside the polygon
> you may want
> intersects (lines.geom, cells.geom)
> or if you want to ignore the touches only relationship
> ( crosses (lines.geom, cells.geom) or within(lines.geom, cells.geom) )
> or
> ( intersects (lines.geom, cells.geom) and not touches(lines.geom,
> cells.geom) )
> C.
> >Thanks,
> > Brent Wood
> >_______________________________________________
> >postgis-users mailing list
> >postgis-users at postgis.refractions.net
> >http://postgis.refractions.net/mailman/listinfo/postgis-users
