[postgis-users] Help with spatial query (bug??)
Carl Anderson
carl.anderson at vadose.org
Wed Apr 6 15:54:49 PDT 2005
Carl Anderson wrote: Brent Wood wrote:
> Thanks Carl.
> Apologies for the length of this post, but I can't see why what I
> think is
> effectively the same query returns two different results.
> My problem turned out to be that a linestring with 2 points does
> not intersect
> with (or relate to) the polygon containing it if the startpoint =
> endpoint. So
> some 10000 records with 0 length lines disappeared from the join.
So to my understanding a zero length linestring has a null interior
and a null boundary
Therefore the disjoint test cannot pass and cannot fail. A bit like
the equality operator versus any NULL
select '' = NULL (answer is NULL)
select '' != NULL (answer is NULL)
select ( '' = NULL ) is null (answer is true)
Ok a little more checking
gis=# select disjoint ('LINESTRING(0 0,0 0)',expand('POLYGON((0 0,0
1,1 1,1 0,0 0))'::geometry,3));
disjoint
t
(1 row)
gis=# select intersects ('LINESTRING(0 0,0 0)',expand('POLYGON((0 0,0
intersects
f
(1 row)
gis=# select intersects ('LINESTRING(0 0,0 0)','POLYGON((0 0,0 1,1 1,1
0,0 0))'::geometry); intersects
t
(1 row)
To my understanding the Boundary test is being carried out and the
Interior test is not
I think that this case should not return TRUE or FALSE but should return
NULL
C.
> (I looked for but could not find an assertion on Linestrings that
> required the interval to exist. The document
> that would assert that OGC 96-015r1 does not seem to be available
> anymore).
> Why does the BBOX operator && give results that include the 0 length
> linestrings
> select getbbox('LINESTRING(0 0,0 0)'::geometry);
> getbbox
> BOX(0 0,0 0)
> the && (overlaping) operator for boundingboxes uses left of, right of,
> below, and above tests
> and does make use of the interior, boundary, and exterior concepts.
> So the two queries are apples and oranges in this case and are testing
> different things.
> C.
>> I'm not sure if this constitutes a bug or not (I'm using v0.8 & can't
>> change
>> that easily)
>> All the linestrings in this data subset have 2 points.
>> Each of the two points is the same, so the lines are zero length.
>> Each cell is a lat/long square, so the bounding box is the actual
>> polygon.
>> (In the main dataset, where non-zero length lines are present, the
>> queries
>> appear to work correctly for non-zero length linestrings)
>> Query one:
>> psql $DB -c "select t.event_key,
>> c.cell_id,
>> x(startpoint(t.the_geom)),
>> y(startpoint(t.the_geom)),
>> c.the_geom from chat_cells3 c,
>> test_junk t
>> where c.the_geom && t.the_geom;"
>> The output shows lines on the boundary of cells, with all the cells
>> being
>> identified which touch or contain the line (point). A line(point) on
>> the vertex
>> of four neighbouring cells gets 4 records returned.
>> event_key | cell_id | x | y
>> | the_geom
>> 13683355 | 3553 | 175.5 | -44.2 | SRID=4326;POLYGON((175.45
>> -44.25,175.45 -44.2,175.5 -44.2,175.5 -44.25,175.45 -44.25))
>> 13683355 | 3554 | 175.5 | -44.2 | SRID=4326;POLYGON((175.45
>> -44.2,175.45 -44.15,175.5 -44.15,175.5 -44.2,175.45 -44.2))
>> 13683355 | 3625 | 175.5 | -44.2 | SRID=4326;POLYGON((175.5
>> -44.25,175.5 -44.2,175.55 -44.2,175.55 -44.25,175.5 -44.25))
>> 13683355 | 3626 | 175.5 | -44.2 | SRID=4326;POLYGON((175.5
>> -44.2,175.5 -44.15,175.55 -44.15,175.55 -44.2,175.5 -44.2))
>> 13677419 | 8186 | 178.68333 | -42.9833 | SRID=4326;POLYGON((178.65
>> -43,178.65 -42.95,178.7 -42.95,178.7 -43,178.65 -43))
>> 12583686 | 2910 | 175.01667 | -43.9833 | SRID=4326;POLYGON((175
>> -44,175
>> -43.95,175.05 -43.95,175.05 -44,175 -44))
>> 12578235 | 3198 | 175.23333 | -43.95 | SRID=4326;POLYGON((175.2
>> -44,175.2 -43.95,175.25 -43.95,175.25 -44,175.2 -44))
>> 12578235 | 3199 | 175.23333 | -43.95 | SRID=4326;POLYGON((175.2
>> -43.95,175.2 -43.9,175.25 -43.9,175.25 -43.95,175.2 -43.95))
>> 12497906 | 12481 | 181.65 | -44.2 | SRID=4326;POLYGON((181.65
>> -44.25,181.65 -44.2,181.7 -44.2,181.7 -44.25,181.65 -44.25))
>> 12497906 | 12482 | 181.65 | -44.2 | SRID=4326;POLYGON((181.65
>> -44.2,181.65 -44.15,181.7 -44.15,181.7 -44.2,181.65 -44.2))
>> 12497906 | 12409 | 181.65 | -44.2 | SRID=4326;POLYGON((181.6
>> -44.25,181.6 -44.2,181.65 -44.2,181.65 -44.25,181.6 -44.25))
>> 12497906 | 12410 | 181.65 | -44.2 | SRID=4326;POLYGON((181.6
>> -44.2,181.6 -44.15,181.65 -44.15,181.65 -44.2,181.6 -44.2))
>> 12497919 | 3270 | 175.26667 | -43.95 | SRID=4326;POLYGON((175.25
>> -44,175.25 -43.95,175.3 -43.95,175.3 -44,175.25 -44))
>> 12497919 | 3271 | 175.26667 | -43.95 | SRID=4326;POLYGON((175.25
>> -43.95,175.25 -43.9,175.3 -43.9,175.3 -43.95,175.25 -43.95))
>> 12497936 | 2841 | 174.98333 | -43.8333 | SRID=4326;POLYGON((174.95
>> -43.85,174.95 -43.8,175 -43.8,175 -43.85,174.95 -43.85))
>> 12497956 | 4856 | 176.38333 | -43.8666 | SRID=4326;POLYGON((176.35
>> -43.9,176.35 -43.85,176.4 -43.85,176.4 -43.9,176.35 -43.9))
>> (16 rows)
>> the second query uses not disjoint, which with this data, I
>> understand should
>> give the same result. In fact only 2 records are returned. Same if I use
>> intersects, relate, add in an "or touches" etc.
>> psql $DB -c "select event_key,
>> c.cell_id,
>> test_junk t
>> and not disjoint(t.the_geom, c.the_geom);"
>> | the_geom
>> -44.2,175.5
>> -44.2,181.65
>> (2 rows)
>> I can't see why I get two different results???
>> I guess the simple fix is to move the (or add a new) endpoint some tiny
>> distance from the startpoint to create a line of non-zero length.
>> Is there a (relatively) simple way to do this in PostGIS v0.8?
>> Thanks again,
>> Brent Wood
>>> Brent Wood wrote:
>>>> I'm trying to make sense of the various spatial operators. I need
>>>> to join a
>>>> table of cells to a table of lines, to create a table where there is a
>>> record
>>>> for each case where a line passes entirely or partially through a
>>>> cell.
>>>> Looking at the OGC specs was a bit of help, but can anyone explain the
>>>> difference between the intersects, overlaps & crosses functions:
>>>> ie:
>>>> select .... where
>>>> lines.geom && cell.geom and
>>>> <one of>
>>>> intersects(lines.geom, cell.geom)
>>>> overlaps(lines.geom, cell.geom)
>>>> crosses(lines.geom, cells.geom)
>>>> I figure I should be using crosses for this query, but don't
>>>> undertand the
>>>> distinction between these.
>>> L - references the Line geometry
>>> A - references the cell, Polygon (area) geometry
>>> intersects (L,A) - line and polygon (cell) touch or overlay in any
>>> way
>>> overlaps (L,A) - is not defined for a line vs polygon test
>>> crosses (L,A) - line is part in and part out of the polygon, but not
>>> wholly inside
>>> within (L,A) - the line is wholly inside the polygon
>>> contains (A,L) - the line is wholly inside the polygon
>>> you may want intersects (lines.geom, cells.geom)
>>> or if you want to ignore the touches only relationship
>>> ( crosses (lines.geom, cells.geom) or within(lines.geom,
>>> cells.geom) )
>>> or
>>> ( intersects (lines.geom, cells.geom) and not touches(lines.geom,
>>> cells.geom) )
>>> C.
>>>> Thanks,
>>>> Brent Wood
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
