[postgis-users] Help with spatial query (bug??)
Stephen Woodbridge woodbri at swoodbridge.com
Wed Apr 6 19:07:54 PDT 2005
I would concur with Brent, if I had a valid line with a length, but all
the length was in Z, the the XY length of the line would be zero, but it
still should be contained in the polygon.
Seems to me anyway,
   -Steve W.
Brent Wood wrote:
> --- Carl Anderson <carl.anderson at vadose.org> wrote:
>>Ok a little more checking
>>gis=# select   disjoint ('LINESTRING(0 0,0 0)',expand('POLYGON((0 0,0
>>1,1 1,1 0,0 0))'::geometry,3));
>> disjoint
>> t
>>(1 row)
>>gis=# select   intersects ('LINESTRING(0 0,0 0)',expand('POLYGON((0 0,0
>> intersects
>> f
>>(1 row)
>>gis=# select   intersects ('LINESTRING(0 0,0 0)','POLYGON((0 0,0 1,1 1,1
>>0,0 0))'::geometry);  intersects
>> t
>>(1 row)
>>To my understanding the Boundary test is being carried out and the
>>Interior test is not
>>I think that this case should not return TRUE or FALSE but should return
>>NULL
> I beg to differ (but do appreciate your comments):
> Surely a line comprising one coordinate (or multiple vertices at the same
> point) should return the same result from these queries as a point at the same
> location?
> If the line had a null geometry the the null result is appropriate. A zero
> length line geometry is not the same as null. Since the locations of all the
> line's vertices are specified, as they are for the polygons, a valid spatial
> overlay is possible, and the result of an overlay should therefore be t/f.
> Unfortunately, the wrong t/f is returned in some cases at present.
> Brent
> postgis-users mailing list
