[postgis-users] problem with intersection
Markus Schaber schabi at logix-tt.com
Wed Apr 6 23:25:11 PDT 2005
Hi, Olivier,
olivier dorie schrieb:
> I'm using PostgreSQL 7.4.6 with Postgis 0.9.0 and geos 2.1.0.
> When I intersect the 2 following polygons, the answer is an exception :
> select intersection('POLYGON((588912.7 2432104.5,588927.7 2432124,
> 588928.9 2432123.6, 588923.7 2432132.3,588912.7
> 2432104.5))','POLYGON((588916.4 2432124.4, 588920.7 2432129.9,588928.6
> 2432123.7,588930.1 2432122.6,588916.4 2432124.4))');
> NOTICE:  TopologyException: no outgoing dirEdge found (588929,2.43212e+06)
> ERREUR:  GEOS Intersection() threw an error!
> I think the polygons are valid. is there a problem with the intersection
> or in my installation ?
Hmm, isvalid() returns true for both polygons in my installation, and I
get the same error on intersection, so I think you possibly found a bug.
Markus
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20050407/b69163ac/attachment.pgp>
