[postgis-users] [OT] Allowing network client connections
John Cole
john.cole at uai.com
Thu Apr 7 14:11:27 PDT 2005
Robert, check the tcpip_socket = false line and make sure it's true. See
http://archives.postgresql.org/pgsql-cygwin/2004-06/msg00060.php for more
detail.
Hope that helps...
John
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Robert
Aldridge
Sent: Thursday, April 07, 2005 1:43 PM
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] [OT] Allowing network client connections
Thanks for the replies. But, my problem must be
deeper. Changing the pg_hba.conf file doesn't seem to
make any difference. Even if I have either
'host all 192.168.0.0 255.255.255.0 trust'
or
'host all 192.168.1.0/24 trust'
I still get:
'no pg_hba.conf entry for host "192.168.1.101", user
"postgres", database "mydatabase"'
when trying to connect from a network client. It's as
if the pg_hba.conf file that I'm editing isn't even
the one it's using.
I thought it may be my firewall/proxy, but the request
seems to be reaching the postgres server because the
logfile on the postgres server shows:
'FATAL: no pg_hba.conf entry for host "192.168.1.101",
user "postgres", database "mydatabase"'
Thanks for your suggestions. Any others?
Robert
Date: Thu, 7 Apr 2005 16:51:03 +0200
From: "TECHER Jean David" <davidtecher at yahoo.fr>
client connections
To: "PostGIS Users Discussion"
<postgis-users at postgis.refractions.net>
Message-ID: <004601c53b81$38afc330$117fa8c0 at jenna>
Content-Type: text/plain; charset="iso-8859-1"
Hi Robert
it's
not
host all 192.168.0.0 255.255.0.0 trust
U did a error in SubNet: 255.255.255.0 and not
255.255.0.0
Date: Thu, 7 Apr 2005 11:20:44 -0400
<robe.dnd at cityofboston.gov>
Subject: RE: [postgis-users] [OT] Allowing network
client connections
To: 'PostGIS Users Discussion'
Message-ID:
<B318FD8D29DCD411BD0500D0B7A91C6704103DDB at jupiter>
Your
Looks right.
Your
host mydatabase 192.168.1.0/24
I would get rid of as it doesn't even designate the
method of trust.
I'm
not sure what happens in that case or put trust at the
end of it.
What does your "Reject all other connections look
like?" Not sure why
you
would need such a line unless you are rejecting a
subset of your
subnet.
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
