[postgis-users] [OT] Allowing network client connections
Obe, Regina DND\MIS robe.dnd at cityofboston.gov
Fri Apr 8 05:27:45 PDT 2005
I think the default location where postmaster looks for the pg_hba.conf file
is in the same folder as your data cluster.
With that said, your pg_hba.conf should be put in your
/usr/local/pgsql/data
Which it doesn't appear you have it.
-----Original Message-----
From: Robert Aldridge [mailto:bamarob55 at yahoo.com]
Sent: Thursday, April 07, 2005 10:10 PM
To: robe.dnd at cityofboston.gov; postgis-users at postgis.refractions.net
Subject: RE: [postgis-users] [OT] Allowing network client connections
Thanks again for the replies.  I think Regina Obe is
getting to the bottom of my problem.  When I run:
select * from pg_settings where name= 'hba_file'
I get no records returned.
Now, I have 'pg_hba.conf' in /etc/postgresql/ and a
symbolic link to this file in /var/lib/postgres/data/
(this is my $PGDATA directory).   I'm starting the
postmaster with:
'/usr/local/pgsql/bin/postmaster -i -D
/usr/local/pgsql/data >logfile 2>&1 &'
So, why isn't it reading pg_hba.conf?
Thanks,
Robert Aldridge
__________________________________
Do you Yahoo!?
Read only the mail you want - Yahoo! Mail SpamGuard.
http://promotions.yahoo.com/new_mail
