[postgis-users] RC6 + ArcObjects
strk at refractions.net
Tue Apr 12 10:43:17 PDT 2005
Abe, if you want to find out you should try to provide
a simple SQL-only script showing the problem.
--strk;
On Tue, Apr 12, 2005 at 12:06:05PM -0400, Abe Gillespie wrote:
> I'm dabbling in connecting / using PostGIS in ESRI ArcObjects. I'm
> experiencing intermittent problems though. I've included the code I'm
> using below. I realize there are three different technologies
> entering the mix here: Npgsql, PostGIS, and ArcObjects. However, I'm
> led to believe the problem is with PostGIS and not the others; this
> use to fail *every* time in earlier PostGIS releases.
> The thing to notice is different runs produce different outputs. The
> output being the IDs of the records throwing exceptions.
> I've attached the sql script of the problematic data. I'd appreciate
> it if anyone could look into this but also realize this problems spans
> multiple areas of expertise.
> Thansk.
> -Abe
> // begin code -->
> using System;
> using ESRI.ArcObjects.Core;
> using Npgsql;
> namespace WKB
> class Program
> static void Main(string[] args)
> // Connect to PostGIS and query.
> NpgsqlConnection con = new NpgsqlConnection(connectionString);
> con.Open();
> NpgsqlCommand cmd = con.CreateCommand();
> cmd.CommandText = "select asbinary(the_geom) as shape,gid
> from roads;";
> NpgsqlDataReader dr = cmd.ExecuteReader();
> // Setup objects and ArcObjects.
> object bin;
> IGeometry geo;
> int byteCnt;
> GeometryEnvironmentClass geoEnv = new GeometryEnvironmentClass();
> while (dr.Read())
> bin = null;
> geo = null;
> byteCnt = 0;
> bin = dr["shape"];
> try
> // Try to convert raw data into an ArcObject.
> geoEnv.CreateGeometryFromWkbVariant(bin, out geo,
> out byteCnt);
> catch
> // There was a failure.
> // The exception always has a generic description.
> Console.WriteLine(dr["gid"].ToString());
> continue;
> static private string connectionString { get { return
> "your_con_str_here"; } }
> // <-- end code.
> postgis-users mailing list
