[postgis-users] RC6 + ArcObjects
Darren Houston
dhouston at beyondcompliance.ca
Tue Apr 12 12:26:25 PDT 2005
Hello Abe,
I didn't spend much time on the following situation so I don't know how
correct this statement is.
I have a friend who is playing around with MySQL WKB and ArcObjects. He is
having similar problems as you. Looking deeper, he found that the WKB
ArcObjects produced is not the same as WKB from MySQL and therefore probably
PostGIS. I looked at the WKB that he sent me for the same point from
ArcObjects and MySQL - MySQL looked correct but ArcObjects WKB looked wrong
(it started off with what looked like default bits for padding or something
else specific to ArcObjects). I would honestly look at the WKB objects from
ArcObjects as the problem, comparing input and output. Like I said, I looked
at both WKB outputs and told my friend "MySQL is right, ArcObjects is wrong".
That is as far as I took it. But nonetheless, I hope this helps you some.
Darren H.
On April 12, 2005 11:51 am, Abe Gillespie wrote:
> The SQL query always succeeds. It's when the WKB data is converted to
> an ArcObject via geoEnv.CreateGeometryFromWkbVariant(bin, out geo, out
> byteCnt) do I encounter intermittent problems. I realize this could
> be a problem with the CreateGeometryFromWkbVariant call, but could it
> be data from PostGIS causing the problem? I'm not sure how to verify
> this.
> -Abe
> On Apr 12, 2005 1:43 PM, strk at refractions.net <strk at refractions.net> wrote:
> > Abe, if you want to find out you should try to provide
> > a simple SQL-only script showing the problem.
> > --strk;
> > On Tue, Apr 12, 2005 at 12:06:05PM -0400, Abe Gillespie wrote:
> > > I'm dabbling in connecting / using PostGIS in ESRI ArcObjects. I'm
> > > experiencing intermittent problems though. I've included the code I'm
> > > using below. I realize there are three different technologies
> > > entering the mix here: Npgsql, PostGIS, and ArcObjects. However, I'm
> > > led to believe the problem is with PostGIS and not the others; this
> > > use to fail *every* time in earlier PostGIS releases.
> > > The thing to notice is different runs produce different outputs. The
> > > output being the IDs of the records throwing exceptions.
> > > I've attached the sql script of the problematic data. I'd appreciate
> > > it if anyone could look into this but also realize this problems spans
> > > multiple areas of expertise.
> > > Thansk.
> > > -Abe
> > > // begin code -->
> > > using System;
> > > using ESRI.ArcObjects.Core;
> > > using Npgsql;
> > > namespace WKB
> > > class Program
> > > static void Main(string[] args)
> > > // Connect to PostGIS and query.
> > > NpgsqlConnection con = new
> > > NpgsqlConnection(connectionString); con.Open();
> > > NpgsqlCommand cmd = con.CreateCommand();
> > > cmd.CommandText = "select asbinary(the_geom) as shape,gid
> > > from roads;";
> > > NpgsqlDataReader dr = cmd.ExecuteReader();
> > > // Setup objects and ArcObjects.
> > > object bin;
> > > IGeometry geo;
> > > int byteCnt;
> > > GeometryEnvironmentClass geoEnv = new
> > > GeometryEnvironmentClass();
> > > while (dr.Read())
> > > bin = null;
> > > geo = null;
> > > byteCnt = 0;
> > > bin = dr["shape"];
> > > try
> > > // Try to convert raw data into an ArcObject.
> > > out byteCnt);
> > > catch
> > > // There was a failure.
> > > // The exception always has a generic description.
> > > Console.WriteLine(dr["gid"].ToString());
> > > continue;
> > > static private string connectionString { get { return
> > > "your_con_str_here"; } }
> > > // <-- end code.
> > > _______________________________________________
> > > postgis-users mailing list
> > > postgis-users at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
