[postgis-users] Distances from geometries other than points
strk at refractions.net
Fri Apr 15 01:58:19 PDT 2005
On Fri, Apr 15, 2005 at 08:52:16AM +0100, Julian Scarfe wrote:
> >I have a table of worldwide objects with a WGS84 latitude-longitude
> >location as a POINT with SRID=4326.
> >To find objects within specified earth-surface distances of a POINT seems
> >straightforward using e.g.:
> >distance_spheroid(
> > object.location,
> > PointFromText('POINT (0.5 52.5)', 4326),
> > 'SPHEROID["WGS_1984", 3444.0, 298.257223563]'
> >to calculate, for example, the distance in nautical miles.
> >But I'd like to be able to find all those objects within specified
> >earth-surface distances (different for each object) of other geometries,
> >for example a line or rectangle.
> >How can I do that, please? distance_spheroid(geometry, geometry) seems to
> >support only points and distance(geometry, geometry) returns a
> >"flat-earth" distance.
> OK, so if no one will bite on that one, let me ask a slightly different
> question.
> Can I extend PostGIS to incorporate functions that allow me to find, e.g.
> shortest distances on a sphere between a point and a line (great circle),
> and if so, where should I look to find out how to do that? [I'm not asking
> for algorithms, which I have, I'm wondering how to add functions that
> accept geometries as parameters, and for examples.]
Take a look at lwgeom/measures.c for examples of working with LWGEOM
types, then look at lwgeom/lwgeom_functions_basic.c to see how to
make wrappers for postgresql. Feel free to ask me if you encounter
any problem.
--strk;
> Thanks
> Julian Scarfe
> postgis-users mailing list
