[postgis-users] Re: PostGIS table structure
Sean Fulton
fulton at cmu.edu
Fri Apr 15 21:58:16 PDT 2005
Eli Dylan Lorimer wrote:
> Hi,
> I'm going to be tracking myself with a gps for the next few months and
> will be storing the collection of waypoints in a PostgreSQL/PostGIS db
> for subsequent visualization. I'm just now trying to figure out the best
> table structure to use. Although I'm pretty unfamiliar with spatial
> databases in general, I believe I'll want to store the lat/lon as point
> objects, correct? As the primary purpose of storing all this info is so
> that I may examine spatio-temporal patterns in it, the time stamp for
> each waypoint is very important too. Can anyone recommend a general way
> to go about storing this data? I'm just looking for a few general ideas
> and/or pitfalls to avoid so as not to screw myself in the end. Much thanks.
Take a look at gpx2shp <http://gpx2shp.sourceforge.jp/>. I believe it
supports time attributes. Loading the resulting shapefile into Postgres
should be much easier than doing a table by hand.
Sean
