[postgis-users] WARNING: cache reference leak: cache pg_statistic (31), tuple 0 has count 1
Ron Mayer
rm_postgis at cheapcomplexdevices.com
Mon Apr 18 01:11:21 PDT 2005
While, I'm at it, I think this patch fixes both the problems.
In LWGEOM_gist_joinsel() inside #ifdef REALLY_DO_JOINSEL I think I see
two problems.
1. It can divide by zero, causing a
"ERROR: invalid join selectivity: inf"
error. I work around this by returning DEFAULT_GEOMETRY_SEL
if the thing on the bottom in that division was zero.
2. I think it can do a "SearchSysCache()" and "get_attstatsslot()"
for stats1_tuple without a corresponding "RelasesSysCache()" or
"free_attstatsslot()" in the case when stats2_tuple has no
statistics. I work around this by putting in the
calls to
free_attstatsslot(0, NULL, 0, (float *)geomstats1, geomstats1_nvalues);
ReleaseSysCache(stats1_tuple);
in the places where I do an early return because of stats2_tuple.
Am I on the right track? It seems to make the problem go
away for me, but I'm not that familiar with the code...
Ron
rmap:~/apps/tmp/postgresql-8.0.2/contrib/postgis-cvs/lwgeom> diff -c lwgeom_estimate.c.~1~ lwgeom_estimate.c
*** lwgeom_estimate.c.~1~ Fri Mar 25 01:34:25 2005
--- lwgeom_estimate.c Sun Apr 17 09:04:57 2005
*** 25,31 ****
#include "liblwgeom.h"
#include "lwgeom_pg.h"
! //#define DEBUG_GEOMETRY_STATS 1
#if USE_VERSION >= 80
--- 25,31 ----
! #define DEBUG_GEOMETRY_STATS 1
*** 867,872 ****
--- 867,874 ----
#if DEBUG_GEOMETRY_STATS
elog(NOTICE, " No statistics, returning default estimate");
#endif
+ free_attstatsslot(0, NULL, 0, (float *)geomstats1, geomstats1_nvalues);
+ ReleaseSysCache(stats1_tuple);
PG_RETURN_FLOAT8(DEFAULT_GEOMETRY_SEL);
*** 878,883 ****
--- 880,887 ----
elog(NOTICE, " STATISTIC_KIND_GEOMETRY stats not found - returning default geometry selectivity");
#endif
ReleaseSysCache(stats2_tuple);
*** 963,968 ****
--- 967,976 ----
elog(NOTICE, "Estimated rows returned: %f", rows_returned);
#endif
+ /* avoid a "ERROR: invalid join selectivity: inf" */
+ if (total_tuples==0)
+ PG_RETURN_FLOAT8(DEFAULT_GEOMETRY_JOINSEL);
PG_RETURN_FLOAT8(rows_returned / total_tuples);
Ron Mayer wrote:
> I have some queries that are giving me a
> " WARNING: cache reference leak: cache pg_statistic (31), tuple 0 has
> count 1 "
> warning message in my log file when I run them.
> I'm using a couple days ago's (either thursday or friday's) CVS version.
> According to the wonderfully helpful people on postgresql's IRC,
> "the catcache issues that warning at the end of a transaction if
> there are outstanding references to cached items ...
> since it's pg_statistic that is being complained about, the most
> likely culprit is a selectivity estimator function.. since those
> use rows from pg_statistic to base estimates on"
> The problem goes away if I "ANALYZE" all my tables involved in the query.
> I can re-create the problem by doing TRUNCATE TABLE on the table
> wiith the MULTIPOLYGON and re-inserting the data, and running the
> query before analyzing that table.
> Below is
> 1. An example query that shows the problem. It's joining a POINT
> from the table point_features with a MULTIPOLYGON from the
> table area_features.
> 2. The output from select * from postgis_full_version();
> and
> 3. A previous message from this list that I think might be related;
> since this is the same kind of query that was giving me
> errors with RC4 when I had non-recently analyzed tables.
> Ron
> === My problem query
> fli=# select *
> from userfeatures.point_features upf,
> userfeatures.area_features uaf
> where upf.the_geom && uaf.the_geom
> and intersects(upf.the_geom,uaf.the_geom)
> and uaf.featureid=18 limit 1
> fli-# fli-# fli-# fli-# fli-# ;
> count 1
> pointid | featureid | sessionid | userid | extid | label | iconid
> | the_geom | entity_id | areaid |
> featureid | session\
> id | userid | extid | label | color | bordercolor
> the_geom
> 3391 | 20 | 0 | 1635480986 | -1 | | 1 |
> 010100000018E29102631355C0606B040DBF743E40 | 29646 | 57 |
> 18 | \
> 0 | 1635480986 | | | green | green |
> 0106000000010000000103000000010000002300000001ACAD4CE01255C02B7ED6AE7A723E407E0D4B0DFB1255C0E0E5C5FE7D\
> 723E40BC2EF520151355C01929CF1E96723E403A4C21872D1355C049D49A21C2723E40B9F3C54F431355C0A4E22E5600733E40F87B94A4551355C0DC5692584E733E40185C35D1631355C054C75129\
> A9733E40E05C364A6D1355C00D80FD4A0D743E407F7566B2711355C08C147FE476743E40929B6ADE701355C07F9AF4E6E1743E40C34A68D66A1355C0771F9D354A753E40F85FB5D55F1355C070954D\
> CEAB753E40615C9048501355C06A33E0F002763E40537FF7C73C1355C067541A444C763E4035A3C713261355C0E9D49DF684763E4006B55C0B0D1355C005D8A1DAAA763E40E74FFCA4F21255C0833A\
> 627BBC763E407C938711DA1255C0EBECE119C3763E40FF31EA50BF1255C03685F2C9BF763E40C110403DA51255C0FD41E9A9A7763E4043F313D78C1255C0CD961DA77B763E40C44B6F0E771255C072\
> 8889723D763E4085C3A0B9641255C03A142670EF753E4065E3FF8C561255C0C2A3669F94753E409DE2FE134D1255C009EBBA7D30753E40FEC9CEAB481255C08A5639E4C6743E40EBA3CA7F491255C0\
> 97D0C3E15B743E40BAF4CC874F1255C09F4B1B93F3733E4085DF7F885A1255C0A6D56AFA91733E401CE3A4156A1255C0AC37D8D73A733E402AC03D967D1255C0AF169E84F1723E40489C6D4A941255\
> C02D961AD2B8723E40778AD852AD1255C0119316EE92723E4096EF38B9C71255C09330564D81723E4001ACAD4CE01255C02B7ED6AE7A723E40
> (1 row)
> fli=#
> fli=#
> =========postgis_full_version()
> fli=# select * from postgis_full_version();
> POSTGIS="1.0.0RC6" GEOS="2.1.1" PROJ="Rel. 4.4.9, 29 Oct 2004"
> USE_STATS DBPROC="0.3.0" RELPROC="0.3.0"
> (1 row)
> fli=#
> ==== possibly related earlier conversation, that I don't remember
> ==== the conclusion of.
> (Re: [postgis-users] ERROR: invalid join selectivity: inf)
> strk at refractions.net wrote:
>> Mark, can you look at this ?
>> As a short-term workaround, in lwgeom_estimate.c line 100:
>> #define REALLY_DO_JOINSEL 0
>> --strk;
>> On Fri, Mar 04, 2005 at 03:01:32AM -0800, Ron Mayer wrote:
>>> Ok.. I think I can reproduce this:
>>>> fl# select * from rtgr.landpoly,userfeatures.areas
>>>> where rtgr.landpoly.the_geom && userfeatures.areas.the_geom;
>>> pretty easily.
>>> Every time I "truncate table userfeatures.areas", and insert
>>> some areas; I'll get that error message until I "analyze areas".
>>> Seems like a bug when the stastics generated by analyze thinks
>>> that a table is empty while in reality it isn't.
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
