[postgis-users] function geomfromtext(box3d, integer) does not exist
strk at refractions.net strk at refractions.net
Wed Apr 20 03:17:58 PDT 2005
On Wed, Apr 20, 2005 at 12:10:55PM +0200, Markus Schaber wrote:
> Hi, Achim,
> Achim Weßling schrieb:
> > in postgis 0.8.1 the function takes the parameters as geometry and int4,
> > in postgis 1.0.0 RC6 the function takes the parameters as text and int
> > 4!
> The PostGIS 1.0.0 function is the correct one, as it should only accept
> OpenGIS compliant WKT specifications.
> As a workaround, you can use setsrid('BOX3D(...)',31467) which should
> work on both releases.
> > But the docu for RC 6 which I downloaded just a few days, has an example
> > of using box3d as I did!
> Hups, it seems that the docu is out of date there.
I've fixed this in current CVS.
Unfortunately it didn't get into 1.0.0.
--strk;
> Markus
> postgis-users mailing list
