[postgis-users] problem with lwpostgis.sql
Jean David TECHER davidtecher at yahoo.fr
Thu Apr 21 07:12:29 PDT 2005
Hi
As Sandro said the most important think is the first ERROR U had...
When U did configure did U do
a complete configure???
cd postgis-1.0.0 (I supposed U are i PGSRL_SRC/contrib)
./configure --with-geos=/usr/local/bin/geos-config --with-proj=/usr/local
--enable-autoconf
See the stdout did by configure to see if Geos and Proj are OK...
An other possibility is to check that your DB didn't exist before ...
TECHER Jean David
01MAP
e-mail: david at 01map.net
Tél: 04 67 45 60 27
Entreprise: http://www.01map.net
Perso: http://techer.pascal.free.fr/postgis/
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Thursday, April 21, 2005 3:11 PM
Subject: RE: [postgis-users] problem with lwpostgis.sql
I had a similar problem.  My linux admin said he ran "ldconfig -v" as
root
That fixed it.
Liz
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of strk at refractions.net
> Sent: April 21, 2005 4:56 AM
> To: postgis-users at postgis.refractions.net
> Subject: Re: [postgis-users] problem with lwpostgis.sql
> The interesting part of the error is the initial one, the
> first ERROR is meaningful, the other just says an error
> occurred before and thus every command is ignored. --strk;
> On Thu, Apr 21, 2005 at 02:54:20PM +0800, ?? wrote:
> > Hi!
> > when  install postgis 1.0.0,
> > $createlang plpgsql test (ok,test is mydatabase)
> > $psql -f lwpostgis.sql -d test (this is not ok)
> > part of error message:
> > -------------------------------error
> > message-----------------------------
> > ERROR:  current transaction is aborted, commands ignored
> until end of transaction block
> > psql:lwpostgis.sql:3008: ERROR:  current transaction is
> aborted, commands ignored until end of transac
> > tion block
> > psql:lwpostgis.sql:3013: ERROR:  current transaction is
> > tion block
> > psql:lwpostgis.sql:3018: ERROR:  current transaction is
> > tion block
> > psql:lwpostgis.sql:3024: ERROR:  current transaction is
> > tion block
> > psql:lwpostgis.sql:3029: ERROR:  current transaction is
> > tion block
> > psql:lwpostgis.sql:3034: ERROR:  current transaction is
> > tion block
> > psql:lwpostgis.sql:3039: ERROR:  current transaction is
> > tion block
> > psql:lwpostgis.sql:3044: ERROR:  current transaction is
> > tion block
> > psql:lwpostgis.sql:3052: ERROR:  current transaction is
> > tion block
> > psql:lwpostgis.sql:3057: ERROR:  current transaction is
>       tion block
> > psql:lwpostgis.sql:3062: ERROR:  current transaction is
>       tion block
> > psql:lwpostgis.sql:3071: ERROR:  current transaction is
>       tion block
> > psql:lwpostgis.sql:3077: ERROR:  current transaction is
>       tion block
> > psql:lwpostgis.sql:3083: ERROR:  current transaction is
>       tion block
> > ROLLBACK
> > whereis wrong ?How do? Please help me,thanks very much!
> > The following is how i  install postgis :
> > tar zxvf postgis-1.0.0.tar.gz
> > copy postgis-1.0.0 to path/postgresql-8.0.1/contrib
> > cd path /postgresql-8.0.1/contrib (the following operation
> all in this
> > DIR)
> > #LDFLAGS=-lstdc++ ./configure --enable-autoconf --with-geos=
> > postgis-users mailing list postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
