[postgis-users] CVS: HEAD and 1.0 branch
strk at refractions.net
Thu Apr 21 17:50:48 PDT 2005
It looks like our last branch confused many people.
Current CVS HEAD branch is aimed at becoming 1.1.0 and
contains new experimental code.
If you are looking for 1.0.1 bound one you should
use a CVS client and checkout the pgis_1_0 branch
(cvs checkout -r pgis_1_0)
The undefined reference you get with CVS HEAD are very
interesting to make the new code work. If you can
show us more that will help.
--strk;
On Thu, Apr 21, 2005 at 09:37:18PM +0200, Gérald Fenoy wrote:
> After reading some compilation errors on window I've just tried the
> ebuild I've made but it is broken (using the postgis-cvs autopgenerated
> archive). This is broken only because of the generation of the doc so
> it's not so bad as it may look like.
> For compilation on Windows we obtain only a lot of undefined
> references ... The configure wroks and the make fail on linking (it
> pass the rest just cause we do an : "export CPPFLAGS="${CPPFLAGS}
> -I/c/the/path/to/your/PostgreSQL/port/win32" command just before
> launching the configure script to include correctly the headers).
> I realy don't know what happen, nevertheless I could suppose that the
> linker expect for library that is not in the Makefile. But where I'm
> lost is here : the compilation works cleanly on linux (and I could be
> considered as n00b in this :) ) so for my point of view all the
> necessary linkages are in the makefile.
> Sorry for my confused mail but I want to express my disapointement ...
> I am not able to solve the problem ... maybe not enough memory in my
> mind ..
> We continue to work on it ...
> postgis-users mailing list
