[postgis-users] Purpose of mesure value in 4D geoms
strk at refractions.net
Fri Apr 22 06:42:33 PDT 2005
On Fri, Apr 22, 2005 at 08:38:22AM -0500, Richard_D_Levine at raytheon.com wrote:
> postgis-users-bounces at postgis.refractions.net wrote on 04/22/2005 07:36:49
> AM:
> > On Fri, Apr 22, 2005 at 01:58:15PM +0200, Markus Schaber wrote:
> > > Hi, Jeremy,
> > > Jeremy Palmer schrieb:
> > > > Sorry if this seems to be a simple question but could someone explain
> > > > the use and purpose of the M value in the new lwgeom geometry
> structure.
> > > You can use it for lean storage of measured values if you record geo
> > > coded measured values. E. G. with an XYZM geometry you can record
> > > position and height above ground and air pressure, or with an XYM
> > > geometry you can store longitude, latitude and fuel level of a ship.
> > > The alternative is to use plain XY(Z) geometries and store the measured
> > > values into their own table columns.
> > Be aware that the Z value of a XYZ will probably have defined semantic
> > in upcoming OGC standards.
> Defined as what? Altitude from Mean Sea Level perhaps?
Check out 99-402r2 from OGC. Best bet is crowling in this list
archives (or postgis-devel ones). See also doc/ZMSgeoms.txt in
postgis distribution, it refers to the former.
--strk;
> Rick
> > --strk;
> > > Markus
> > > _______________________________________________
> > > postgis-users mailing list
> > > postgis-users at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
